Greetings, I'm having trouble with a menu I meed for a project I'm doing.
I have two sensors and thinking of adding one more(Already programed one of them which is a flow sensor, the other one is an oxigention sensor), and I need to be able to go in the menu and select which reading I want to see, for example I want to see the flow reading, select to see it for as long as I want and being able to go back to the main menu so I can scroll and look for another sensor.
I'm using an encoder and a Adruino uno.
I've been using this code but it's just working with leds. I dont know how to adapt it to just show the sensor reading instead of turning the leds on and off.
#include <Wire.h>
#include <LiquidMenu.h>
LiquidCrystal_I2C lcd(0x27, 16, 2);
//ENCODER
#define outputA 6
#define outputB 7
#define sw 4
int aState;
int aLastState;
//LEDS
#define led1 8
#define led2 9
#define led3 10
int led_seleccionado = 0;
LiquidLine linea1(1, 0, "Flujo");
LiquidLine linea2(1, 1, "Sp02");
LiquidLine linea3(1, 0, "Ritmo");
LiquidLine linea4(1, 1, "Otros");
LiquidScreen pantalla1(linea1,linea2,linea3,linea4);
LiquidLine linea1_2(1, 0, "Encender");
LiquidLine linea2_2(1, 1, "Apagar");
LiquidLine linea3_2(1, 0, "Atras");
LiquidScreen pantalla2(linea1_2,linea2_2,linea3_2);
LiquidMenu menu(lcd,pantalla1,pantalla2);
pinMode(led1,OUTPUT);
pinMode(led2,OUTPUT);
pinMode(led3,OUTPUT);
pinMode(sw,INPUT_PULLUP);
lcd.init();
lcd.backlight();
menu.init();
linea1.set_focusPosition(Position::LEFT);
linea2.set_focusPosition(Position::LEFT);
linea3.set_focusPosition(Position::LEFT);
linea4.set_focusPosition(Position::LEFT);
linea1.attach_function(1, fn_led1);
linea2.attach_function(1, fn_led2);
linea3.attach_function(1, fn_led3);
linea4.attach_function(1, fn_todos);
menu.add_screen(pantalla1);
linea1_2.set_focusPosition(Position::LEFT);
linea2_2.set_focusPosition(Position::LEFT);
linea3_2.set_focusPosition(Position::LEFT);
linea1_2.attach_function(1, fn_on);
linea2_2.attach_function(1, fn_off);
linea3_2.attach_function(1, fn_atras);
menu.add_screen(pantalla2);
pantalla1.set_displayLineCount(2);
pantalla2.set_displayLineCount(2);
menu.set_focusedLine(0);
menu.update();
selectOption();
aState = digitalRead(outputA);
if (aState != aLastState){
if (digitalRead(outputB) != aState) {
menu.switch_focus(false);
menu.switch_focus(true);
menu.update();
aLastState = aState;
//Funciones:::::
void selectOption(){
if(digitalRead(sw) == LOW){
menu.call_function(1);
void fn_led1(){
menu.change_screen(2);
led_seleccionado = 1;
void fn_led2(){
led_seleccionado = 2;
void fn_led3(){
led_seleccionado = 3;
void fn_todos(){
void fn_on(){
switch(led_seleccionado){
case 1:
digitalWrite(led1,HIGH);
case 2:
digitalWrite(led2,HIGH);
case 3:
digitalWrite(led3,HIGH);
case 0:
void fn_off(){
case 1:
digitalWrite(led1,LOW);
case 2:
digitalWrite(led2,LOW);
case 3:
digitalWrite(led3,LOW);
case 0:
void fn_atras(){
menu.change_screen(1);
And this is the code for the flow meter I am using
#include <Wire.h>
LiquidCrystal_I2C lcd(0x27,16,2);
const int ontime (200);
const int offtime (200);
const int buzzer= 11;
const int led = 12;
volatile int flow_frequency; // Measures flow sensor pulses
unsigned int l_mint; // Calculated litres/hour
unsigned char flowsensor = 2; // Sensor Input
unsigned long currentTime;
unsigned long cloopTime;
void flow () // Interrupt function
flow_frequency++;
pinMode(buzzer, OUTPUT);
pinMode(led, OUTPUT);
pinMode(flowsensor, INPUT);
digitalWrite(flowsensor, HIGH); // Optional Internal Pull-Up
attachInterrupt(0, flow, RISING); // Setup Interrupt
sei(); // Enable interrupts
currentTime = millis();
lcd.init();
lcd.backlight();
cloopTime = currentTime;
lcd.print(" Flow meter");
delay(2000);
lcd.clear();
void loop ()
// Every second, calculate and print litres/mint
if(currentTime >= (cloopTime + 1000))
cloopTime = currentTime; // Updates cloopTime
// Pulse frequency (Hz) = 7.5Q, Q is flow rate in L/min.
l_mint = (flow_frequency * 60 / 98); // (Pulse frequency x 60 min) / 7.5Q = flowrate inL/mint
flow_frequency = 0; // Reset Counter
Serial.print(l_mint, DEC); // Print litres/hour
Serial.println(" L/mint");
lcd.setCursor(0,0);
lcd.print(" Flow Meter");
lcd.setCursor(0,1);
lcd.setCursor(2,1);
lcd.print(l_mint, DEC);
lcd.setCursor(5,1);
lcd.print("L/Min");
if(l_mint>=10)
digitalWrite(led, HIGH);
digitalWrite(buzzer, HIGH);
delay(ontime);
if(l_mint<10){
digitalWrite(led,LOW);
digitalWrite(buzzer, LOW);
delay(offtime);
Thanks in advance
