Display temperature sensor readings through wifi shield
Hi, I am new in the Arduino world. I am trying to print readings from a DS18B20 temperature sensor on web server. I am using a Mega 2560 and Arduino WiFi Shield. I cant print anything on the web server page but I am able to connect the WiFi network.
Can anyone please help me with this.
Thank you in advance for your guidance.
#include <SPI.h>
#include <WiFi.h>
#include <OneWire.h>
#include <DallasTemperature.h>
#define ONE_WIRE_BUS 2   // Data wire is plugged into port 2 on the Arduino
char ssid[] = "username";      //  your network SSID (name)
char pass[] = "Network password";   // your network password
int keyIndex = 0;                 // your network key Index number (needed only for WEP)
int status = WL_IDLE_STATUS;
WiFiServer server(80);
// Setup a oneWire instance to communicate with any OneWire devices (not just Maxim/Dallas temperature ICs)
OneWire oneWire(ONE_WIRE_BUS);
// Pass our oneWire reference to Dallas Temperature.
DallasTemperature sensors(&oneWire);
int tempC;
  //Initialize serial and wait for port to open:
  Serial.println("starting data sending...");
  while (!Serial) {
    ; // wait for serial port to connect. Needed for Leonardo only
  // check for the presence of the shield:
  if (WiFi.status() == WL_NO_SHIELD) {
    Serial.println("WiFi shield not present");
    // don't continue:
    while(true);
  // attempt to connect to Wifi network:
  while ( status != WL_CONNECTED) {
    Serial.print("Attempting to connect to SSID: ");
    Serial.println(ssid);
    // Connect to WPA/WPA2 network. Change this line if using open or WEP network:
    status = WiFi.begin(ssid, pass);
    // wait 10 seconds for connection:
    delay(10000);
  server.begin();
  // you're connected now, so print out the status:
  printWifiStatus();
  // start serial port
  Serial.println("Dallas Temperature IC Control Library Demo");
  // Start up the library
  sensors.begin();
  // listen for incoming clients
  WiFiClient client = server.available();
  if (client) {
    Serial.println("new client");
    // an http request ends with a blank line
    boolean currentLineIsBlank = true;
    while (client.connected()) {
      if (client.available()) {
        char c = client.read();
        Serial.write(c);
        // if you've gotten to the end of the line (received a newline
        // character) and the line is blank, the http request has ended,
        // so you can send a reply
        if (c == '\n' && currentLineIsBlank) {
          // send a standard http response header
          client.println("Content-Type: text/html");
          client.println("Connnection: close");
          client.println();
          client.println("<!DOCTYPE HTML>");
          client.println("<html>");
          client.println("<meta http-equiv=\"refresh\" content=\"5\">");
          int digitalChannel = 0;
          client.print("Temperature in Celcius:");
          client.print(tempC);
          client.print("degrees C");
          client.print("
          client.println("</html>");
        if (c == '\n') {
          // you're starting a new line
        else if (c != '\r') {
          // you've gotten a character on the current line
          currentLineIsBlank = false;
    // give the web browser time to receive the data
    delay(1);
    // close the connection:
    client.stop();
    Serial.println("client disonnected");
  // call sensors.requestTemperatures() to issue a global temperature
  // request to all devices on the bus
  Serial.print("Requesting temperatures...");
  sensors.requestTemperatures(); // Send the command to get temperatures
  Serial.println("DONE");
  tempC = sensors.getTempCByIndex(0);
  Serial.print("Device 1 (index0) =");
  Serial.print(tempC);
  Serial.print("Degrees C");
void printWifiStatus() {
  // print the SSID of the network you're attached to:
  Serial.print("SSID: ");
  Serial.println(WiFi.SSID());
  // print your WiFi shield's IP address:
  IPAddress ip = WiFi.localIP();
  Serial.print("IP Address: ");
  Serial.println(ip);
  // print the received signal strength:
  long rssi = WiFi.RSSI();
  Serial.print("signal strength (RSSI):");
  Serial.print(rssi);
  Serial.println(" dBm");
Problem solved.
used the breakpoints to check where the code stops working.
What breakpoints? Where did it stop?
Yes, please elaborate. I'd like to hear some hands-on debugging detail because I'm currently stuck. Do you mean actual software break points, with a debugger? Or just debugging print statements?
Sorry for the late reply, but i used print statements.
I am not sure why it wasn’t working before .
but this works fine.
I found some code online, so it has a refresh button on web page
#include <SPI.h>
#include <WiFi.h>
char ssid[] = "User Name";      //  your network SSID (name)
char pass[] = "Password";   // your network password
float tempC;
float tempF;
float rssi;
  Serial.println("check point 1");
  while (!Serial) {
  Serial.println("check point 2");
    // don't continue:
    while(true);
  Serial.println("check point 3");
    Serial.println("check point 4");
    Serial.println("check point 5");
    delay(10000);
  Serial.println("check point 6");
  server.begin();
  printWifiStatus();
  sensors.begin();
  if (client) {
        Serial.write(c);
          client.println();
          client.println("<meta http-equiv=\"refresh\" content=\"25\">");
          client.println(F("<td align=\"center\" valign=\"center\"><font size=\"12\" color=\"green\">&nbsp;&nbsp;****PUT YOUR HEADING HERE****&nbsp;&nbsp;</font></td>"));
          client.print("
          client.print("
          client.print(F("<font color=\"red\">"));
          client.print("IP Address of the Device:      ");
          client.print(WiFi.localIP());  // prints the ip address of the device
          client.print("
           client.print("Signal Strength (RSSI):      ");   // prints the signal strength on the web server page
           client.print(WiFi.RSSI());
           client.println("   dBm");
            client.print("
          client.print(F("<font color=\"blue\">"));
          client.print("
          client.print("Temperature in Celsius:        ");
          client.print("    degrees C");
           client.print("
           client.print("Temperature in Fahrenheit:      ");
          client.print(tempF = tempC*1.8 + 32.00);     // converting Celsius to fahrenheit
          client.print("    Degrees F");
          client.print("
          // creates an HTML form with a refresh button that reloads the page with out any variables
          client.print("<FORM action=\"http://*****PUT the IP address where you want it to reload it to *****/\">");
          client.print("<P> <INPUT type=\"submit\" value=\"Refresh\"> </FORM>");
          client.print("<img src = 'https://api.cosm.com/v2/feeds/61098/datastreams/sensor1.png?width=500&height=250&colour=%230000cc&duration=1day&legend=Degrees%20Farenheit&title=Apartment%20Temperature&show_axis_labels=true&detailed_grid=true&scale=auto&timezone=UTC'>");
        if (c == '\n') {
    delay(1);
    client.stop();
  Serial.print("Sensor is ONLINE");
  Serial.print("Device 1 (index0) =    ");
  Serial.print("    Degrees C");
  Serial.println(ip);
  Serial.print("signal strength (RSSI):      ");
  Serial.print(rssi);
