Display temperature with 4 digit 7 segment display using MAX7219
Hello
I could need some help in developing my programm.
I want to display the temperature which is read by a DS18S20 on a 4digit 7segment display using the MAX7219. The sensor is working. I tried it. The 7segment display works too. I used the LedControl-Library.
Now i want to connect it. But I don’t know how.
Anyone who could help me?
That’s the code I used testing the DS18S20:
// Include the libraries we need
#include <OneWire.h>
#include <DallasTemperature.h>
// Data wire is plugged into port 2 on the Arduino
#define ONE_WIRE_BUS 2
// Setup a oneWire instance to communicate with any OneWire devices (not just Maxim/Dallas temperature ICs)
OneWire oneWire(ONE_WIRE_BUS);
// Pass our oneWire reference to Dallas Temperature.
DallasTemperature sensors(&oneWire);
 * The setup function. We only start the sensors here
void setup(void)
  // start serial port
  Serial.println("Dallas Temperature IC Control Library Demo");
  // Start up the library
  sensors.begin();
 * Main function, get and show the temperature
void loop(void)
  // call sensors.requestTemperatures() to issue a global temperature
  // request to all devices on the bus
  Serial.print("Requesting temperatures...");
  sensors.requestTemperatures(); // Send the command to get temperatures
  Serial.println("DONE");
  // After we got the temperatures, we can print them here.
  // We use the function ByIndex, and as an example get the temperature from the first sensor only.
  Serial.print("Temperature for the device 1 (index 0) is: ");
  Serial.println(sensors.getTempCByIndex(0));
Thank you
techniclover
Where is the code for 7 segment display?
For testing i used this code:
#include <LedControl.h>
// inputs: DIN pin, CLK pin, LOAD pin. number of chips
LedControl mydisplay = LedControl(11, 13, 7, 1);
  mydisplay.shutdown(0, false);  // turns on display
  mydisplay.setIntensity(0, 15); // 15 = brightest
  mydisplay.setDigit(0, 0, 9, false);
  mydisplay.setDigit(0, 1, 8, false);
  mydisplay.setDigit(0, 2, 2, false);
  mydisplay.setDigit(0, 3, 6, false);}
But like I said I don’t know how I can programm to display the temperature
