I created another program without the Button and my analog value is max 1012. That means I have a problem with the Button function (maybe librarie).
No, your problem is that you are getting more readings than you are averaging. If you take 6 readings, all of which are near 1020, add them up (total is about 6120) and then divide by 5, you will get a value over 1023. (Approximately 1224).
This appears to be what is happening to you.
Try this, instead:
sensorValue = 0; // Initialize to 0
for (int i=0; i< sampleCount ; i++)
sensorValue += analogRead(A0); // Read and add up the sensor value
sensorValue /= sampleCount; // Divide by the actual number of readings taken
Can I use it like this because I want to skip the first and the last reading and to average just the middle values. I want to read 5 times and average the middle 3 Values...
int sensorValue = 0; // The sensor value
sensorValue = analogRead(A0);
// only while the button is pushed
if (btn.isButtonPressed()) {
// read the sensor X times and average the total, skipping the 1st Y readings
for (int i=0; i< skipCount ; i++) analogRead(A0);
I used the sequece that you said and I have the same problem, returns values bigger then 1023.
Here is the part of code that I use:
#define sampleCount 5
btn.loop();
//for (int i=0; i< skipCount ; i++) analogRead(A0);
Here is the entire code. The libraries are attached above in this post.
Breathalyzer with Arduino UNO using a MQ-3 alcohol sensor and Serial LCD from SparkFun
#include <SoftwareSerial.h>
#include "serLCD.h"
#include "Button.h"
// Set pin to the LCD's rxPin
int pin = 2;
serLCD lcd(pin);
// Set button pin
Button btn(7);
lcd.clear();
//Push the button to start
lcd.print("Apasa-ti butonul");
lcd.print("pentru a incepe!");
btn.setup(); // setup & describe the button's normal state
btn.normallyOpen(); // button closes circuit when pressed
//btn.normallyClosed(); // button opens circuit when pressed
btn.buttonCold(); // button shorts to sink
//btn.buttonHot(); // button shorts to voltage
bool isButtonPressed ( void ); // is the button in the opposite of normal state ?
bool buttonMoved ( void ); // did the button change ?
#define skipCount 2
btn.loop();
sensorValue /= sampleCount + 1;
//detection concentartion scope is between 0.04 to 4 mg/L
float mappedValue = map(sensorValue, 120, 1023, (0.04*100.00),(4.00*100.00))/100.00;
lcd.clear();
lcd.print("Alcool: ");
if (mappedValue >= 0.04)
lcd.print(mappedValue);
lcd.print("0.00");
lcd.print("mg/L");
//averaged raw value
lcd.print(sensorValue);
delay(2000);
I mark with orange my opinion about readings. However something it's not owrite....
#define skipCount 2
btn.loop();
sensorValue = analogRead(A0); [color=orange]// first read[/color]
[color=orange]// read the sensor 5 or 6, I'm not sure [/color]and average the total, skipping the 1st Y readings
for (int i=0; i< skipCount ; i++) analogRead(A0); [color=orange]// read 2 times and skip them[/color]
for (int i=0; i< sampleCount ; i++) [color=orange]// read 5 times[/color]
sensorValue += analogRead(A0); [color=orange]// sum the values[/color]
sensorValue /= sampleCount + 1; [color=orange]// divide the sum to 6[/color]
