Hello,
I have small problem, if i light a led (5V + pin 12 on arduino MEGA) the LCD display falls in brightness (letters is not vissible as much)
Can you help me how to fix it?
Thanks
Hello,
Thanks
Post your code and a diagram of how your circuit is constructed.
Is the LCD connected to pin 12 in any way ?
Have you got a resistor in series with the LED ?
That meaned LED is called "ledka"
I have a resistor on + led. - is turned to 5V directly to arduino port and led is directly hooked to pin 12
I found that description of how it is wired hard to follow. Can you provide a diagram, even if it is hand drawn.
problem solved, it is bugging only when it's powered up by USB from PC, if i connect 11,1v lipo battery, it's fine.
Tomas1993:
That doesn't sound like a solution, it should work when powered from the USB.
problem solved,
No it's not, you have just worked round it, that's all.
Why did you remove the code from your post ?
