'display' was not declared in this scope
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#define sensor A0
#define SCREEN_WIDTH 128
#define SCREEN_HEIGHT 64
#include "DHT.h"
#define DHTPIN 2
#define DHTTYPE DHT11
DHT dht(DHTPIN, DHTTYPE);
Adafruit_SSD1306 oled(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, -1);
void show(int position, char* text);
dht.begin();
pinMode(7, OUTPUT);
pinMode(6, OUTPUT);
pinMode(5, OUTPUT);
display.startscrollright();
display.stopscroll();
if (!oled.begin(SSD1306_SWITCHCAPVCC, 0x3C)) {
  Serial.println(F("SSD1306 allocation failed"));
  while (true);
delay(2000);
oled.clearDisplay();
oled.setTextSize(2);
oled.setTextColor(WHITE);
oled.setCursor(45, 1);
oled.println("CO2");
oled.display();
int level = analogRead(A0);
Serial.print(level);
Serial.print("ppm");
delay(200);
display.startscrollright(0x00, 0x0F);
delay(2000);
if (level <= 100)  {
  oled.setCursor(45, 50);
  oled.println("CLEAN");
  oled.setCursor(22, 30);
  oled.println(level);
  oled.setCursor(72, 30);
  oled.println("ppm");
  oled.display();
  digitalWrite(6, HIGH);
  delay(100);
  digitalWrite(6, LOW);
  delay(100);
else if (level <= 150) {
  oled.println("NORMAL");
  oled.display();
  delay(100);
  delay(100);
else if (level <= 200) {
  oled.setCursor(25, 50);
  oled.println("MEDIOCRE");
  oled.display();
  digitalWrite(7, HIGH);
  delay(100);
  digitalWrite(7, LOW);
  delay(100);
else if (level <= 250) {
  oled.println("HIGH");
  oled.setCursor(32, 30);
  oled.display();
  delay(100);
  delay(100);
else if (level > 300)  {
  oled.setCursor(20, 50);
  oled.println("VERY HIGH");
  oled.display();
  digitalWrite(5, HIGH);
  delay(999);
  digitalWrite(5, LOW);
  delay(999);
float humi  = dht.readHumidity();
float tempC = dht.readTemperature();
if (isnan(humi) || isnan(tempC)) {
  Serial.println("Failed to read from DHT sensor!");
  Serial.print("Humidity: ");
  Serial.print(humi);
  Serial.print("%");
  Serial.print("  |  ");
  Serial.print("Temperature: ");
  Serial.print(tempC);
  Serial.print("°C ~ ");
display.clearDisplay();
display.setTextSize(1);
display.setCursor(0, 0);
display.print("Temperature: ");
display.setTextSize(2);
display.setCursor(0, 10);
display.print(tempC);
display.print(" ");
display.cp437(true);
display.write(167);
display.print("C");
display.setCursor(0, 35);
display.print("Humidity: ");
display.setCursor(0, 45);
display.print(humi);
display.print(" %");
display.display();
error code
C:\Users\amish\Documents\Arduino\sketch_dec17a\sketch_dec17a.ino: In function 'void setup()':
sketch_dec17a:21:3: error: 'display' was not declared in this scope
C:\Users\amish\Documents\Arduino\sketch_dec17a\sketch_dec17a.ino:21:3: note: suggested alternative: 'delay'
   delay
C:\Users\amish\Documents\Arduino\sketch_dec17a\sketch_dec17a.ino: In function 'void loop()':
sketch_dec17a:46:3: error: 'display' was not declared in this scope
C:\Users\amish\Documents\Arduino\sketch_dec17a\sketch_dec17a.ino:46:3: note: suggested alternative: 'delay'
   delay
C:\Users\amish\Documents\Arduino\sketch_dec17a\sketch_dec17a.ino: At global scope:
sketch_dec17a:190:1: error: expected declaration before '}' token
Multiple libraries were found for "Adafruit_SSD1306.h"
 Used: C:\Users\amish\Documents\Arduino\libraries\Adafruit_SSD1306
 Not used: C:\Users\amish\Documents\Arduino\libraries\Adafruit_SSD1306-master
 Not used: C:\Users\amish\Documents\Arduino\libraries\Adafruit_SSD1306_Wemos_Mini_OLED
Multiple libraries were found for "DHT.h"
 Used: C:\Users\amish\Documents\Arduino\libraries\DHT_sensor_library
 Not used: C:\Users\amish\Documents\Arduino\libraries\NanoPlayBoard
exit status 1
option enabled in File -> Preferences.
i am using an 128x64 OLED screen for display and an MQ-135 for CO2 and a DHT11 aensor
Erik_Baas:
Please add code tags before and after your code, using the </> button.
its actually my first time posting in the forum so i am not sure what do u mean
Read the how get the most out of this forum sticky to see how to properly post code. Remove useless white space and format the code with the IDE autoformat tool (crtl-t or Tools, Auto Format) before posting code.
The display was constructed using the name oled, not display.
You're creating an instance of the Adafruit_SSD1306 class named 'oled' but trying to use an instance named 'display' which you did not create.
