DISPLAY WILL NOT WORK ALONGSIDE SD
I have multiple tabs within this code. The code is for a display and for data logging to an SD card. But, when I add in the line " if (!card.init(SPI_HALF_SPEED, chipSelect)){ " the display stops showing the correct values and instead shows 0.00 .
here is my code (not in full, just the card.h tab)
// code for SD card
#include <SD.h>
#include <SPI.h>
#include "setting.h"
Sd2Card card;
SdVolume volume;
SdFile root;
const char chipSelect=(10,11,12,13);
void setup2() {
    Serial.print("\nInitializing SD card...");
    pinMode(53, OUTPUT);
 if (!card.init(SPI_HALF_SPEED, chipSelect)){           // This line stops display working
    Serial.println("initialization failed. Things to check:");
    Serial.println("* is a card inserted?");
    Serial.println("* is your wiring correct?");
    Serial.println("* did you change the chipSelect pin to match your shield or module?");
    return;
  Serial.println("Wiring is correct and a card is present.");
  return;
It would be great if anyone could help me get the display and SD working alongside eachother,
Thank you
strange..
Some SD-readers doesn't release MI. This can cause problems
If you really want help:
  1. press ctrl-T to format your code nicely.
  2. ZIP up your multi-tab project i.e. the project directory
  3. attach the ZIP file.
This applies to any coding problem. It takes you 1 minute to provide the complete information.
A small sketch can be pasted to a CODE window in your message.
A long sketch or multiple-tab sketch is better as an attachment.
David.
Ok, some code might be commercially sensitive.
Or teachers do not want you to post a school assignment.
In which case you create a minimal program that exhibits your problem.
From knut_ny's reply in #1 you have a lot to learn.
Hint.
  1. does it even compile?
  2. what value does it assign to chipSelect ?
David.
