Display
Hi
MY new 2.4 inch TFT lcd display (28 pins, RED colored PCB) is working with my uno. display ID is 9338
I used Adafruit_GFX & MCUfriend libraries
now the problem is all 28 pins in uno are occupied. I want to connect some analogue sensors.
how can i find out whether my display is using SPI communication or not. if it runs on SPI i think i will get some pins free. If it runs on SPI what are the pins that i should inter connect. I dont want to insert the display right on top of the uno as i want to connect the sensors too.
thanks in advance.
The TFT (and Touch) uses 2-9 and A0-A4.
The only spare Analog pin is A5.
But if you are not using the microSD you have the SPI pins available i.e. digital 10-13.
David.
Hi David
Is this display capable of running in 8 bit parallel mode & SPI mode? I believe with MCUfriend library it is running in 8 bit parallel mode. To use the SD card I think SPI mode should be selected
can i do this with the present libraries or will i have to try Adafruit_TFTLCD library?
Thanks in advance.
The SD.h library uses the hardware SPI pins.
You should install libraries via the IDE Library Manager.
Then run all the examples that come with MCUFRIEND_kbv
If you have a problem, quote the MCUFRIEND_kbv example sketch by name.
David.
