The purpose of my code and project is to display a text sequence (the one stored in the text String) byte by byte on 8 LEDs.
I uploaded my code on the attiny 84a I am using for this project.( I tested the attiny setup with a simpler code and the LEDs light up correctly.)
There wasn't any error message; the code uploaded succesfuly. However it is not working as expected and I can't figure out where the flaw could be.
Thanks in advance!
int led0 = 6;
int led1 = 7;
int led2 = 5;
int led3 = 8;
int led4 = 0;
int led5 = 2;
int led6 = 9;
int led7 = 10;
String text = "01110100011001010111001101110100";
pinMode(led0, OUTPUT);
pinMode(led1, OUTPUT);
pinMode(led2, OUTPUT);
pinMode(led3, OUTPUT);
pinMode(led4, OUTPUT);
pinMode(led5, OUTPUT);
pinMode(led6, OUTPUT);
pinMode(led7, OUTPUT);
int x = text.length();
for(int i = 0; i <= x + 1; i++){
switch (i % 8) {
case 0:
if (text.charAt(i) == "1"){
digitalWrite(led0, HIGH);
case 1:
digitalWrite(led1, HIGH);
case 2:
digitalWrite(led2, HIGH);
case 3:
digitalWrite(led3, HIGH);
case 4:
digitalWrite(led4, HIGH);
case 5:
digitalWrite(led5, HIGH);
case 6:
digitalWrite(led6, HIGH);
case 7:
digitalWrite(led7, HIGH);
delay(3000);
digitalWrite(led0, LOW);
digitalWrite(led1, LOW);
digitalWrite(led2, LOW);
digitalWrite(led3, LOW);
digitalWrite(led4, LOW);
digitalWrite(led5, LOW);
digitalWrite(led6, LOW);
digitalWrite(led7, LOW);
You have very inefficient code.
Firstly, it would be more correct to organize the pins for the LEDs in an array, then you won’t need switch-case to access them, but simply give a pin by index
Secondly, in a computer, all data is ALREADY stored in binary form, so it would be more correct to store text as text. not as a string of zeros and ones.
To extract bits from bytes of text, use bitwise operations.
Addition:
While I was writing, @PaulRB already posted an example of such code
I've been reading about a null element at the end of a string and I wasn't sure if it is included in the output of .length(). Nevertheless, it was irrelevant, as the LEDs didn't work not even for the first iterations of the for loop.
Thanks for the suggestions. It looks very promising, however, I'm not so familiar with the syntax you used so I'm not able to figure out why I get this error message when trying to upload the code:
sketch_dec24c:1:16: error: 'ledCount' was not declared in this scope
const byte led[ledCount] = {6, 7, 5, 8, 0, 2, 9, 10};
C:\Users\alexa\AppData\Local\Temp\arduino_modified_sketch_884528\sketch_dec24c.ino:1:16: note: suggested alternative: 'lround'
lround
C:\Users\alexa\AppData\Local\Temp\arduino_modified_sketch_884528\sketch_dec24c.ino: In function 'void setup()':
sketch_dec24c:14:19: error: 'ledCount' was not declared in this scope
for(byte n=0; n<ledCount; n++)
C:\Users\alexa\AppData\Local\Temp\arduino_modified_sketch_884528\sketch_dec24c.ino:14:19: note: suggested alternative: 'lround'
lround
sketch_dec24c:15:13: error: 'led' was not declared in this scope
pinMode(led[n], OUTPUT);
C:\Users\alexa\AppData\Local\Temp\arduino_modified_sketch_884528\sketch_dec24c.ino: In function 'void loop()':
sketch_dec24c:20:21: error: 'ledCount' was not declared in this scope
C:\Users\alexa\AppData\Local\Temp\arduino_modified_sketch_884528\sketch_dec24c.ino:20:21: note: suggested alternative: 'lround'
lround
sketch_dec24c:21:20: error: 'led' was not declared in this scope
digitalWrite(led[n], lowHigh[bitRead(text[i], n)]);
exit status 1
I was aware of the fact that my initial code was not the most efficient, but it was the only one I could come up with. After reviewing the solution you mentioned I really makes sense and I also learned some quite useful new syntax. Thanks again for the help and lesson!
