Displaying and Transmitting digital value of analog output of sensor.
I want to convert sensor analog output voltage in 8 bit digital format and display the value and transmit the value serially.what should be actual code for this as i am new in arduino. kindly help me.
Really basic code:
byte analogValue;
void setup{
Serial.begin(9600); // start serial port
void loop(){
//read an analog pin
analogValue = analogRead(A0)>>2; // 10 bit value converted to 8 bit
Serial.println (analogValue); // send 8 bit value in decimal format (0 to 255) to serial monitor
delay (500); // crudely delay 1/2 second so don't flood PC serial port
I want the DIGITAL OUTPUT in zero(0) or one(1) format for equivalent analog vaule. if sensor analog value is 5v then 8 bit digital output will be 11111111 and sensor analog value is 0v then 8 bit digital output will be 00000000. in this way i have to transmit these digital output of equivalent analog signal should be sent through serially.What should be the code? kindly help me.
Ok, so change this line
to
Serial.println (analogValue, BIN); // send 8 bit value in binary format (00000000 to 11111111) to serial monitor
Thank you.
Now i want to encode the each serial digital value. my encoded program i have written i.e.
pinMode(13, OUTPUT);
while (!Serial) {
; // wait for serial port to connect. Needed for Leonardo only
// send an intro:
Serial.println("ENCODED VALUE");
// get any incoming bytes:
if (Serial.available() > 0) {
int thisChar = Serial.read();
if (thisChar == '0')
digitalWrite(13,HIGH);
Serial.print("1");
digitalWrite(13,LOW);
Serial.print("0");
else {
Serial.print("1");
MY PROBLEM IS THAT WHAT COMMAND SHOULD I USE TO ENCODE EACH BINARY VALUE?
