Displaying flowrate on LCD that coming from two flow hall sensors
Hello everyone
Sorry about my English..
I have to finish my final project so please try to help me :slight_smile:
I'm using Arduino Mega
I have two flow sensor (hall sensor) and i'm trying to write the data about the flow on LCD (16X2) screen, but I get some blankts rectangles
Here is my code
#include <LiquidCrystal.h>
#include <Wire.h>
Pulse Period Measurement of 2 Flow Sensors
• accurate measurements by using Arduino micros() function
• determines leading edge of pulses without use of iterrupts
• calculates pulse periods, frequencies, flow rates, totalized volumes
• includes pulse generator for testing, simulation and troubleshooting
• easily adapted for testing other sensors and pulse quantities (energy, optic, etc.)
- dlloyd ----------------------------------------------------------------------------*/
LiquidCrystal lcd(2,3,4,5,10,11,12);
// constants
const byte pgenPin = 13;  // PGEN pin number
const byte CLEAR = 12;    // CLEAR pin number
const byte inputs[] = {6, 8}; // input pins 6 is inlet 8 is outlet
const double pulseConstant[] = {7.5, 7.5}; // pulse constants
const byte qty = sizeof(inputs);
// variables
double pgenFrequency = 7.5;   // pulse generator frequency (Hz)
long previousMillis = 0;
long pgenInterval = 1000000 / (pgenFrequency * 2);
byte pgenState = LOW;
long pgenPreviousMicros = 0;
long startTime[qty];
byte inputsState[qty];
byte inputsPrevious[qty];
double pulsePeriod[qty];
double pulseFrequency[qty];
double pulseMultiplier[qty];
double flowRate[qty];
double pulseVolume[qty];
double totalVolume[qty];
byte h0[8] = {
  B11111,
  B01010,
  B10101,
  B01010,
  B10101,
  B01010,
  B11111,
 Serial.print("");
 lcd.begin(16,2);
 lcd.clear();
 pinMode(pgenPin, OUTPUT);
 pinMode(CLEAR, INPUT_PULLUP);
 for (int i = 0; i < qty; i++) {
   pinMode(inputs[i], INPUT_PULLUP);
   pulseVolume[i] = 1.0 / (pulseConstant[i] * 60);
   pulseMultiplier[i] = 1.0 / (pulseConstant[i]);
   //lcd.print(flowRate[i], 6); lcd.print(" m^3/sec, ");
   //lcd.setCursor(0,1);
      //lcd.print(flowRate[i+1], 6); lcd.print(" m^3/sec, ");
      //delay(1000);
      //lcd.clear();
 clr(); // initialize arrays
 pgen();  // run pulse generator
 if (digitalRead (CLEAR) == LOW) {  // check CLEAR push button
   clr();
 pulseMeasure();  // run flow tests, calculations and print results
// functions -----------------------------------------------------
void pulseMeasure() {
   inputsState[i] = digitalRead(inputs[i]);                   // read the inputs
   if ((inputsState[i] == 1) && (inputsPrevious[i] == 0)) {   // if rising
     pulsePeriod[i] = (micros() - startTime[i]) * 0.000001;   // test duration (sec)
     pulseFrequency[i] = 1 / pulsePeriod[i];                  // input frequency (Hz)
     flowRate[i] = (pulseFrequency[i] * pulseMultiplier[i])*16.6666667;    //  1.0 / pulseConstant[i] (L/min) (ml/sec)
     totalVolume[i] = totalVolume[i] + pulseVolume[i];        // totalized volume (L)
     if (millis() - previousMillis > 250) {                   // update interval (milliseconds)
       Serial.print(i); Serial.print(": ");
       Serial.print(pulsePeriod[i], 3); Serial.print(" sec, ");
       Serial.print(pulseFrequency[i], 3); Serial.print(" Hz, ");
       Serial.print(flowRate[i], 6); Serial.print(" ml/sec, ");
       lcd.print(flowRate[i], 6); lcd.print(" ml/sec, ");
       Serial.print(totalVolume[i], 6); Serial.print(" L");
       previousMillis = millis();
     startTime[i] = micros();
   inputsPrevious[i] = inputsState[i];
void pgen() {
 // check to see if it's time to pulse the PGEN; that is, if the
 // difference between the current time and last time you pulsed
 // the PGEN is bigger than the interval to changed its output state.
 unsigned long pgenCurrentMicros = micros();
 if (pgenCurrentMicros - pgenPreviousMicros > pgenInterval) {
   // save the last time you pulsed the PGEN
   pgenPreviousMicros = pgenCurrentMicros;
   // if the PGEN output is off turn it on and vice-versa:
   if (pgenState == LOW)
     pgenState = HIGH;
     pgenState = LOW;
   digitalWrite(pgenPin, pgenState);
void clr() {
   inputsState[i] = 0;
   inputsPrevious[i] = 1;
   pulsePeriod[i] = 0;
   pulseFrequency[i] = 0;
   flowRate[i] = 0;
   totalVolume[i] = 0;
Someone have an idea?
(notice: I want to display on the screen only the data of flow rate)
Thank you
Do you see the flow rate in the serial monitor ?
Try to print "Hello" to the lcd, for example in the setup() function and wait 5 seconds, so you can read the text "Hello".
Perhaps the wiring is wrong, or a bad breadboard is used. Or the display is broken (it happens).
