Displaying Images on 800x480 tft w/ SD Card
Hello, I am still new to this (having only messed with UNO R3 in the past. I recently went out and bought a mega 2560 and a 7.0" TFT shield (Resistive Touch SSD1963 w/resistive touchscreen with controller XPT2046) with the plan of making a gauge cluster/ display for a vehicle I am building. I plan to draw my background image upon initial startup and draw 1 needle for tach over the background image. Then display a few other sensor inputs in digital format on the screen however. I am halted at the point of displaying an image on my TFT. While easily accomplished with the UNO and a 2.4 Ada fruit TFT shield. I am having troubles with the mega2560. While spending several days snooping around google I stumbled upon a thread …http://forum.arduino.cc/index.php?topic=288767.msg2025078#msg2025078… where the OP has the same hardware setup as I, how ever I was able to get that sketch to work before my intensive online search for answers. While reading that thread I took notice to “ghlawrence2000” and him talking about using his library “UTFT_SdRaw” for increased speed of drawing images from Sd cards using the .raw format. While trying to run his sketch however, I did have issues installing the “SdFat” library. When finally getting it to show up under my include lib tab, I tried to compile the sketch and received this result.
Arduino: 1.8.1 (Windows 7), Board: "Arduino/Genuino Mega or Mega 2560, ATmega2560 (Mega 2560)"
In file included from C:\Users\Ben\AppData\Local\Temp\arduino_modified_sketch_558211\SdRaw_800x480.ino:12:0:
C:\Users\Ben\Documents\Arduino\libraries\SdFat/SdFat.h:27:33: fatal error: SdSpiCard/SdSpiCard.h: No such file or directory
 #include "SdSpiCard/SdSpiCard.h"
compilation terminated.
exit status 1
Error compiling for board Arduino/Genuino Mega or Mega 2560.
option enabled in File -> Preferences.
What am i missing or have overlooked? I am currently lost. :o :o :o
SdRaw demo sketch included below. Thanks in advance
// UTFT_SdRaw_800x480_Demo
// Copyright (C)2015 Graham Lawrence (GHLawrence2000). All Rights reserved.
// web: https://github.com/ghlawrence2000/UTFT_SdRaw
// This program is a demo of how to use the functions provided by UTFT_SdRaw.
// This program requires the UTFT, URTouch, UTFT_Buttons and SdFat libraries.
#include <SPI.h>
// SdFat lib from here :-
// https://github.com/greiman/SdFat/archive/master.zip
#include <SdFat.h>
#include <UTFT.h>
#include <URTouch.h>
#include <UTFT_Buttons.h>
#include <UTFT_SdRaw.h>
extern uint8_t SmallFont[];
extern uint8_t BigFont[];
#define SD_CHIP_SELECT  53  // SD chip select pin
// file system object
SdFat sd;
// print stream
ArduinoOutStream cout(Serial);
int wait = 2, pressed_button;
// Initialize display
// Set the pins to the correct ones for your development board
// Standard Arduino Uno/2009 Shield            : <display model>,19,18,17,16
// Standard Arduino Mega/Due shield            : <display model>,38,39,40,41
// CTE TFT LCD/SD Shield for Arduino Due       : <display model>,25,26,27,28
// Teensy 3.x TFT Test Board                   : <display model>,23,22, 3, 4
// ElecHouse TFT LCD/SD Shield for Arduino Due : <display model>,22,23,31,33
// Remember to change the model parameter to suit your display module!
//UTFT myGLCD(CPLD, 25, 26, 27, 28);
//UTFT myGLCD(CTE50, 25, 26, 27, 28);
UTFT myGLCD(CTE70, 25, 26, 27, 28);
// Initialize touchscreen
// Standard Arduino Uno/2009 Shield            : 15,10,14, 9, 8
// Standard Arduino Mega/Due shield            :  6, 5, 4, 3, 2
// CTE TFT LCD/SD Shield for Arduino Due       :  6, 5, 4, 3, 2
// CTE TFT LCD/SD Shield for Arduino Due (JP10):  6, 5,32, 3, 2
// Teensy 3.x TFT Test Board                   : 26,31,27,28,29
// ElecHouse TFT LCD/SD Shield for Arduino Due : 25,26,27,29,30
URTouch  myTouch( 6, 5, 32, 3, 2);
//URTouch  myTouch( 6, 5, 4, 3, 2);
UTFT_SdRaw myFiles(&myGLCD);
UTFT_Buttons  myButtons(&myGLCD, &myTouch);
  while (!Serial) {
    ; // wait for serial port to connect. Needed for DUE & Leonardo only
  Serial.println(F("Initialising SD card..."));
  bool mysd = 0;
  // see if the card is present and can be initialized:
  while (!mysd)
    if (!sd.begin(SD_CHIP_SELECT, SPI_FULL_SPEED)) {
      Serial.println(F("Card failed, or not present"));
      Serial.println(F("Retrying...."));
      mysd = 1;
      Serial.println(F("Card initialised."));
  Serial.println(F("Initialising LCD."));
  myGLCD.InitLCD();
  myGLCD.clrScr();
  myGLCD.setFont(SmallFont);
  myTouch.InitTouch();
  myTouch.setPrecision(PREC_MEDIUM);
  myButtons.setTextFont(BigFont);
  int butskip = myButtons.addButton( 85,  219 , 70,  20, "Skip");
  Serial.println(F("LCD initialised."));
  //             Wait for GPS screen  or skip button
  Serial.println(F("Initialising GPS."));
  long mytime = millis();
  myFiles.load(0, 0, 240, 240, "wait4gps.RAW", 1 , 1);
  long mytime1 = millis() - mytime;
  cout << F("Time to draw 240x240 raw ") << mytime1 << F(" ms") << endl;
  myButtons.drawButton(butskip);
  while (wait == 2) {
    pressed_button = myButtons.checkButtons();
    if (pressed_button == butskip)
      cout << F("Skip button detected (No GPS :( )\n");
      wait = true;
  char fname440[] = "SO11/SO100100.RAW";
  myGLCD.clrScr();
  mytime = millis();
  myFiles.load(20, 20, 440, 440, fname440, 1);
  cout << F("Time to draw 440x440 raw (no extra buffer) (non inverted colour) ") << mytime1 << F(" ms") << endl;
  delay(5000);
  myGLCD.clrScr();
  mytime = millis();
  myFiles.load(20, 20, 440, 440, fname440, 32, 0);
  cout << F("Time to draw 440x440 raw (32*buffer) (non inverted colour) ") << mytime1 << F(" ms") << endl;
  delay(5000);
  mytime = millis();
  myFiles.load(20, 20, 440, 440, fname440, 32, 1);
  cout << F("Time to draw 440x440 raw (32*buffer) (inverted colour) ") << mytime1 << F(" ms") << endl;
  delay(5000);
  myGLCD.clrScr();
  mytime = millis();
  myFiles.pan(20, 20, 440, 440, 0, 0, 4040, 4040, "SK45/SK45.RAW", 1);
  cout << F("Time to draw 440x440 portion from 4040x4040 raw image (inverted colour) ") << mytime1 << F(" ms") << endl;
  delay(5000);
  myGLCD.clrScr();
  int xad, yad;
  int xd = 0, yd = 0;
  int tmpx = 0, tmpy = 0;
  mytime = millis();
  for (int z = 0; z < 209; z++)
    tmpy = (z / 19);
    tmpx = z - (tmpy * 19);
    xd = tmpx * 42;
    yd = tmpy * 42;
    tmpy = (z / 22);
    tmpx = z - (tmpy * 22);
    yad = (tmpy * 69) + 10;
    xad = (tmpx * 108) + 44;
    myFiles.pan(xd, yd, 42, 42, xad, yad, 2374, 696, "icons.raw");
  mytime1 = millis();
  cout << F("time to draw 210 42x42 icons (ms) ") << (mytime1 - mytime) << endl;
  delay(5000);
  cout << F("Thanks for watching!") << endl;
  myGLCD.clrScr();
  myGLCD.setFont(BigFont);
  myGLCD.setColor(VGA_GREEN);
  myGLCD.print("Thanks for watching!", CENTER, 231);
