Displaying more than 4 bits on lcd & converting to Binary
I am a beginner programmer. I am making a little project where i read in a value from a 4x4 keypad and displaying the decimal value on the first line of the lcd and on the second line i need to show the binary value. I have already made the conversion from ASCII to DEC, but I cant display a value over 4 bits. For example if I want to show the number 75: when I press 7 , the decimal value and its binary code are being displayed. When i press 5 the display resets and the value 5 and its binary code are being displayed. I want to display 75 on the first line and on the second line the binary value of 75.
can someone help me with this problem?
here the code:
#include<Keypad.h>
#include <LiquidCrystal.h>
const byte ROWS = 4; //four rows
const byte COLS = 4; //four columns
char keys[ROWS][COLS] = {
{'1','2','3','A'},
{'4','5','6','B'},
{'7','8','9','C'},
{'*','0','#','D'}
byte rowPins[ROWS] = {7, 6, 5, 4}; //connect to the row pinouts of the keypad
byte colPins[COLS] = {3, 2, 1, 0}; //connect to the column pinouts of the keypad
Keypad keypad = Keypad(makeKeymap(keys), rowPins, colPins, ROWS, COLS );
LiquidCrystal lcd(A0,A1,A2,A3,A4,A5);
lcd.begin(16,2);
char key = keypad.getKey();
if (key != NO_KEY){;
lcd.setCursor(0,0);
lcd.print(key);
lcd.setCursor(0,1);
key=key-48;
lcd.print(key,BIN);
Your code acts as soon as a key is pressed, and then forgets everything it knows. If you want to remember stuff, you need to write your code differently.
You also need to consider how you will reset the value. Press '7' and '5', and see 75 and it's binary equivalent. Now, you want to see 37 in base 10 and base 2. How will you get rid of the 75?
