Displaying numbers on 7 segment LED.
I got seven 7-segment LED displays, max7219 and I want to send a number via usb to the display.
I wrote a small program in VB.NET to send a number to the Arduino. I'm having a problem though. I made it to work with a single digit numbers, but I can't figure out how to sent bigger numbers. There are two problems. 1. LedControl library can't display number bigger than 9. I have to split it and send it to a specific LED 2. When I send a number to Arduino, VB.NET sends it in ASCII code and on top of that I believe it breaks up the numbers. So when I send 123, it will send it as "49" then "50" then "51"
So the question is, how can I assign a number that I receive on Arduino to a specific LED display?
You could use something like this:
int getInt(){
  // waits for a string of up to 5 ascii digits terminated by any non digit character
  byte counter = 0;
  char buffer[7]; // the biggest arduino int is represented by a 5 byte string, sign if neg and null
  while( counter < 7){
    buffer[counter] = Serial.read();  // block till a char is available
    if( (buffer[counter] >= '0' && buffer[counter] <= '9') || buffer[counter] == '-' ){  // check for digit or minus sign
      counter++; // got a digit so increment counter
    else {
      buffer[counter] = 0;   // not a digit so terminate string and return value
      return (atoi(buffer));
  return 0;  // return 0 if no valid digit is received
The function getInt will block until it gets an ascii string of up to five digits terminated by any non digit character.
It would be used as follows:
int val;
if(Serial.available() >0 ){
val = getInt();
Serial.print("getInt returned ");
Serial.println(val,DEC);
Note that this function will return 0 if its called and the first character read is not a digit (or minus sign). If you want to distinguish between a non digit character and 0, you can use this function instead.
boolean getInt( int* value){
  byte counter = 0;
    if((buffer[counter] >= '0' && buffer[counter] <= '9') || buffer[counter] == '-' ){  // check for digit or minus sign
    else {
      *value = atoi(buffer);
      return counter > 0;  // return true if more than 1 digit received
  return false;  // no valid digit received
It is slightly more complicated to use because you have to pass a pointer to the value you want returned.
int val;
if( getInt(&val) == true) {
Serial.println(“getInt returned false”);
  1. LedControl library can’t display number bigger than 9. I have to split it and send it to a specific LED
  2. When I send a number to Arduino, VB.NET sends it in ASCII code and on top of that I believe it breaks up the numbers. So when I send 123, it will send it as “49” then “50” then “51”
The LedControl-library can handle ascii-chars directly you don’t have to convert them back
see http://www.arduino.cc/playground/Main/LedControl#CharSeg7Control
My idea would be to use some sort of easy protocol for transmitting your numbers. I don’t know how many digits you attached to the MAX7221? lets assume the maximum 8.
On the arduino side you create a buffer of 8 chars and fill it with 8 ASCII characters comingg from the VB.NET app.
The VB-app must fill up the actual value (in ascii) with either space-chars or leading zeros:
int value 123 becomes "     123" or "00000123"
whatever you like better.
When you have received all 8 chars you display them in a loop
//the value coming from the VB-app
LedControl lc=new LedControl(......);
char valueFromVB[8];
for(int i=0;i<8;i++) {
    lc.setChar(ADDRESS_OF_YOUR_DISPLAY,i,valueFromVB[i],false)
Does that help?
Eberhard
