Displaying Received serial data
Hi
I was testing out a stand alone FTDI board to send data between the Arduino and a PC
not via the USB lead on the Arduino
I wanted to send a character from a terminal program on the PC , to be echoed back by the
Arduino to be displayed on the terminal on the PC .
The connection is working fine , I send data , and it sends it back but the problem is , I
am not seeing what I expected to see
Here is the code
int incomingByte = 0;	// for incoming serial data
	Serial.begin(9600);	// opens serial port, sets data rate to 9600 bps
	// send data only when you receive data:
	if (Serial.available() > 0) {
		// read the incoming byte:
		incomingByte = Serial.read();
                // say what you got:
		Serial.print("I received: ");
		Serial.println(incomingByte);
When I send a capital letter "A" ( without quotes)
I see on the monitor ....
I received : 66
Firstly I wanted to see a letter "A" just like I sent so I guess I need to format it in some way
so it shows the character not its ascii code on the terminal.
Secondly and something I cant figure out is "A" has ascii code 65 not 66 which is what I get,
all the codes are incremented by one
can you tell me why this happens and how to recode it so it returns the letter I send
Regards
Don
either declare:
char incoming_byte;
then the print will print out the character,
or cast the int to a char, e.g. Serial.print((char) incoming_byte);
The cast is not good practice really, but useful for debugging.
As for why the code is one out, I have no idea - is it always one out for every character? Is your computer set up 9600, 8 bit, no parity?
The Serial class derives from the Print class. The Print::print() method has several overloads, to print different kinds of data. You are using int overload (because you call the function with an int) and expecting the function to print a char. You need to either store the value returned by Serial.read() in the appropriate type variable (char), or cast the int to a char when printing.
As far as the off-by-one issue, you need to tell us more about this:
Which terminal program? How is the serial communication configured?
Try using the Serial Monitor, to see if the problem manifests itself there, too.
Thank you both for your replies
I didnt know about casting to a different variable type , so I tried both ideas , declare the variable as a char
and that worked fine , and also casting it as Serial.println((char)incomingByte); which of course also worked
as for why I got 66 as a value when it should be 65, well now I feel quite silly . let me explain.
I have a piece of kit that has 3 FT2232D chips in it. It gives me a usb lead to the PC and on plugging it in
I get 6 comms ports , 2 off each chip .
I have one of the comms ports connected to pins 0 and 1 on the arduino
I call up a terminal using PUTTY and the plan was to send a character from putty to the arduino , and then
have the arduino send it back . To prove to my doubting friend that it really made the trip my plan was to add one to its value in the arduino
so sending an A returns a B sending B returns a C etc
When it failed to give me the characters only ascii code numbers I altered the prog , including taking out the bit of code
that adds 1 to the value . What I didnt notice was that when I uploaded the code , although it appeared to succeed , at the bottom
of the page it said that AVR dude was out of sync , or something like that . so really the code never did update and the
ADD one to the received value remained in force .I know why this happened now . I had the outside comms port still connected
to arduino pins 0 and 1 while trying to upload a program, so it failed
So although I feel silly for making the mistake , I still learned about Casting and also to disconect things from pins 0 and one
before uploading , so it was really a good thing because I learned from it
Again , thanks for the help
Don
