Displaying static characters on a 7x5 LED matrix
I am doing something slightly different in that I wish to display static characters on my 7x5 matrix using Arduino Uno. I am using 595 shift register to drive columns and 4017 via transistor array for rows. I cannot get the code to work and would like some help with this if possible.Eventually I would like to cascade several 7x5 matrices to display static characters, is the best way to cascade the 595's and have one per matrix? Also could I use a Max7219 LED driver instead, can this source and limit the correct current? Any help appreciated.
You will need to post your circuit and/or code in order to get meaningful help. Hard to assist otherwise on your specific questions. When you post code use the # button on the posting menu to make it legible in the post.
Hello, basically I copied the design in the following link;
Although I am currently using just a 5x7 matrix, so using just one HC595 to drive columns 1 to 5 and rows 1 to 7 are driven via the 4017 and transistor array. I have cobbled the code together from this example too but modified it appropriately but not sure if correct.
After defining the chracters the code is below;
(code tags added by moderator)
int latchPin = 10;
int clockPin = 13;
int dataPin = 11;
int clock = 9;
int Reset = 8;
int latchPinPORTB = latchPin - 8;
int clockPinPORTB = clockPin - 8;
int dataPinPORTB = dataPin - 8;
int i = 0;
long scrolling_word[6];
int array_turn=0;
byte your_text[8][6]={BH,BI,SPACE,BW,BO,BR,BL,BD};//PUT YOU TEXT HERE
void setup(){
  pinMode(dataPin,OUTPUT);
  pinMode(clockPin,OUTPUT);
  pinMode(latchPin,OUTPUT);
  pinMode(clock,OUTPUT);
  pinMode(Reset,OUTPUT);
  digitalWrite(Reset,HIGH);
  digitalWrite(Reset,LOW);
  setupSPI();
void display_word(int loops,byte word_print[][6],int num_patterns,int delay_langth){// this function displays your symbols
  i = 0;// resets the counter fot the 4017
  for(int g=0;g<6;g++)//resets the the long int where your word goes
    scrolling_word[g] = 0;
  for(int x=0;x<num_patterns;x++){//main loop, goes over your symbols
   // you will need to find a better way to make the symbols scroll my way is limited for 24 columns
   for(int r=0;r<6;r++)//puts the buildes the first symbol
      scrolling_word[r] |= word_print[x][r];
    for (int z=0;z<6;z++){//the sctolling action
        for(int p=0;p<6;p++)
          scrolling_word[p] = scrolling_word[p] << 1;
// end of the scrolling funcion
      for(int t=0;t<delay_langth;t++){// delay function, it just loops over the same display
        for(int y=0;y<6;y++){// scaning the display
          if(i == 6){// counting up to 6 with the 4017
            i = 0;
          latchOff();
          spi_transfer(make_word(0x01000000,y));// sending the data
          spi_transfer(make_word(0x00010000,y));
          spi_transfer(make_word(0x00000100,y));
          latchOn();
          delayMicroseconds(800);//waiting a bit
          latchOff();
          spi_transfer(0);// clearing the data
          spi_transfer(0);
          spi_transfer(0);
          latchOn();
          digitalWrite(clock,HIGH);//counting up with the 4017
          digitalWrite(clock,LOW);
          i++;
  finish_scroll(delay_langth);
void finish_scroll(int delay_scroll){// this function is the same as the funcion above, it just finishing scrolling
  for (int n=0;n<24;n++){
        for(int h=0;h<6;h++)
          scrolling_word[h] = scrolling_word[h] << 1;
      for(int w=0;w<delay_scroll;w++){
        for(int k=0;k<6;k++){
          if(i == 6){
            i = 0;
          latchOff();
          spi_transfer(make_word(0x01000000,k));
          spi_transfer(make_word(0x00010000,k));
          spi_transfer(make_word(0x00000100,k));
          latchOn();
          latchOff();
          spi_transfer(0);
          spi_transfer(0);
          spi_transfer(0);
          latchOn();
          i++;
byte make_word (long posistion,byte turn){
  byte dummy_word = 0;
  for(int q=0;q<8;q++){
    if(scrolling_word[turn] & (posistion<<q))
      dummy_word |= 0x01<<q;
  return dummy_word;
        display_word(1,your_text,8,15);// calls for the display_pattern function and says that int loop = 15(if you do more loop the pattern whould scrole slower).
void latchOn(){
  bitSet(PORTB,latchPinPORTB);
void latchOff(){
  bitClear(PORTB,latchPinPORTB);
void setupSPI(){
  byte clr;
  SPCR |= ( (1<<SPE) | (1<<MSTR) ); // enable SPI as master
  //SPCR |= ( (1<<SPR1) | (1<<SPR0) ); // set prescaler bits
  SPCR &= ~( (1<<SPR1) | (1<<SPR0) ); // clear prescaler bits
  clr=SPSR; // clear SPI status reg
  clr=SPDR; // clear SPI data reg
  SPSR |= (1<<SPI2X); // set prescaler bits
  //SPSR &= ~(1<<SPI2X); // clear prescaler bits
  delay(10);
byte spi_transfer(byte data)
  SPDR = data;			  // Start the transmission
  while (!(SPSR & (1<<SPIF)))     // Wait the end of the transmission
  return SPDR;			  // return the received byte, we don't need that
