Displaying temperature and pressure at the same time using java
Hi!!
I am very new in arduino and in programming (I started 4 days ago :smiley: ). And now I am trying to display the data from my thermistor (from sunfounder) and from my barometer (also from sunfounder BMP280) in the same way that a lot of people are doing: Easy Arduino Data Logging and Telemetry - YouTube . I manage to get the right codes for my thermistor and barometer separately but when I connect the two sensors in my arduino and try to do the same thing that is in the youtube video, It doesnt work entirely. I manege to get the temperature well, in celsius, but the pressure values are not shown in Pa. I cant understand why… Can someone help me with this, please?
Here are the individual codes for the thermistor and barometer:
Thermistor:
#include <Wire.h>
#define analogPin A0 //the thermistor attach to
#define beta 3950 //the beta of the thermistor
#define resistance 10 //the value of the pull-up resistor
long a =1023 - analogRead(analogPin); //read thermistor value
//the calculating formula of temperature
float tempC = beta /(log((1025.0 * 10 / a - 10) / 10) + beta / 298.0) - 273.0;
Serial.println(tempC);
delay(1000); //wait for 100 milliseconds
Barometer:
  • bmp280_example.ino
  • Example sketch for BMP280
  • Copyright (c) 2016 seeed technology inc.
  • Website : www.seeedstudio.com
  • Author : Lambor, CHN
  • Create Time:
  • Change Log :
  • The MIT License (MIT)
  • Permission is hereby granted, free of charge, to any person obtaining a copy
  • of this software and associated documentation files (the “Software”), to deal
  • in the Software without restriction, including without limitation the rights
  • to use, copy, modify, merge, publish, distribute, sublicense, and/or sell
  • copies of the Software, and to permit persons to whom the Software is
  • furnished to do so, subject to the following conditions:
  • The above copyright notice and this permission notice shall be included in
  • all copies or substantial portions of the Software.
  • THE SOFTWARE IS PROVIDED “AS IS”, WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
  • IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
  • FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
  • AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
  • LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
  • OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN
  • THE SOFTWARE.
    #include “Seeed_BMP280.h”
    #include <Wire.h>
BMP280 bmp280;
if(!bmp280.init()){
Serial.println(“Device error!”);
float pressure;
//get and print atmospheric pressure data
Serial.print(bmp280.getPressure());
Serial.println("\n");//add a line between output of different times.
My code following the youtube template to show the two graphs in java:
#include <Wire.h>
BMP280 bmp280;
if(!bmp280.init())
int sensor1 = beta /(log((1025.0 * 10 / a - 10) / 10) + beta / 298.0) - 273.0;
float c = (bmp280.getPressure());
int sensor2 = c;
char text [40];
sprintf (text, “%d, %d\n”, sensor1, sensor2);
Serial.println (text);
With that coding I get this:
25, -28643 (as an example)
Again, the temperature is fine, but I cant understand why the pressure isnt in the correct units…
Can someone help me? :slight_smile:
Cheers!!
float c = (bmp280.getPressure());What units does getPressure return?
Please remember to use code tags when posting code
Sorry!! In pascals. It is really strange because, as soon as I put the Serial.print before the (bmp280.getPressure()) I got the right values: 10241224, 6. But of course in a completely wrong way of displaying the thing. The 102412 is the pressure in pascals the following two and four is the temperature and then I dont know what is the 6 after the comma ahah
You can't fit the pressure in Pascals into a sixteen bit "int".
Use unsigned long
how? Just change the int sensor2 = (...) to long sensor2 = (...)?
Thank you so much for your help!!!
You can use long if you expect to measure negative pressure, but I suggested unsigned long.
Your choice.
I used the unsigned long (just replaced the int sensor2 = (...) to unsigned long sensor2 = (...)) and the values that I am getting are the same: - 28665 (as an example)
Post the code.
#include <Wire.h>
BMP280 bmp280;
if(!bmp280.init())
unsigned long sensor2 = c;
char text [40];
You need to let sprintf know that it's being passed an unsigned long:
  sprintf (text, "%d, %lu\n", sensor1, sensor2);
Yes!!!! Thank you so much to you too!!! Thanksss guys you really made my day happier!
You wouldn't have had the problem if you'd just used Serial.print :slight_smile:
how could I do that? Can you exemplify, please? :slight_smile:
One more thing guys: In the temperature values, I only get exact values like 24,25,26 and not 23.4 , 23.9, 24.56,etc. etc. Do you know why?
You're storing the result of your temperature calc in an integer. By definition, integers don't have a fractional component. Use float instead.
wildbill:
You’re storing the result of your temperature calc in an integer. By definition, integers don’t have a fractional component. Use float instead.
Can you help me with that? I tried to change the code using float but I dont displays the right values
#include <Wire.h>
#include "Seeed_BMP280.h"
BMP280 bmp280;
 if(!bmp280.init())
    Serial.println("Device error!");
 float sensor1 = beta /(log((1025.0 * 10 / a - 10) / 10) + beta / 298.0) - 273.0;
 float c =  bmp280.getPressure();
  char text [40];
  sprintf (text, "%s, %lu\n", sensor1, sensor2);
  delay (500);
You can't use sprintf with floats easily on AVRs, but you'd need to use %f if you could.
As I pointed out earlier, you don't need sprintf.
The format specifier for a float is NOT %s. That is for strings.
By the way, by default, support for floats in sprintf() is disabled.
I assume you're using sprintf because it was in the example code you copied. As mentioned above, you really don't need it:
 Serial.print(Sensor1);
 Serial.print(", ");
 Serial.println(c);
Not tested. Not even compiled.
wildbill:
Serial.print(", ");
Serial.println(c);
Thank you so much guys again! I learnt one more thing thanks to you both!! It worked!! Now I will try to display on a LCD, wish me luck :smiley: ahah
