its not showing anything on lcd.
its not showing any error also.
can anyone help me for modifying this code
#include <SPI.h>
#include <Ethernet.h>
#include <SD.h>
#include "rgb_lcd.h"
#include <Wire.h>
rgb_lcd lcd;
#define REQ_BUF_SZ 90
#define LCD_BUF_SZ 17
byte mac[] = {
0x98, 0x4F, 0xEE,0x01, 0x65, 0x4E };
IPAddress ip(192,168,19,170);
String readString;
EthernetServer server(80); // create a server at port 80
File webFile; // the web page file on the SD card
char HTTP_req[REQ_BUF_SZ] = {0}; // buffered HTTP request stored as null terminated string
char req_index = 0; // index into HTTP_req buffer
char lcd_buf_1[LCD_BUF_SZ] = {0};// buffer to save LCD line 1 text to
char lcd_buf_2[LCD_BUF_SZ] = {0};// buffer to save LCD line 2 text to
//LiquidCrystal lcd(3, 2, 8, 7, 6, 5);
// disable Ethernet chip
pinMode(10, OUTPUT);
digitalWrite(10, HIGH);
Serial.begin(115200); // for debugging
lcd.begin(16, 2);
// Message on LCD
lcd.print(F("Initializing"));
// initialize SD card
Serial.println("Initializing SD card...");
if (!SD.begin(4)) {
Serial.println("ERROR - SD card initialization failed!");
lcd.print(F("SD init failed"));
return; // init failed
Serial.println("SUCCESS - SD card initialized.");
// check for index.htm file
if (!SD.exists("index.htm")) {
Serial.println("ERROR - Can't find index.htm file!");
return; // can't find index file
Serial.println("SUCCESS - Found index.htm file.");
Ethernet.begin(mac, ip); // initialize Ethernet device
server.begin(); // start to listen for clients
// End of initialization message on LCD + print IP address
lcd.clear();
lcd.setCursor(0, 0);
lcd.print(F("Done."));
lcd.setCursor(0, 1);
lcd.print(ip);
EthernetClient client = server.available(); // try to get client
if (client) { // got client?
boolean currentLineIsBlank = true;
while (client.connected()) {
if (client.available()) { // client data available to read
char c = client.read(); // read 1 byte (character) from client
// limit the size of the stored received HTTP request
// buffer first part of HTTP request in HTTP_req array (string)
// leave last element in array as 0 to null terminate string (REQ_BUF_SZ - 1)
if (req_index < (REQ_BUF_SZ - 1)) {
HTTP_req[req_index] = c; // save HTTP request character
req_index++;
// last line of client request is blank and ends with \n
// respond to client only after last line received
if (c == '\n' && currentLineIsBlank) {
// send a standard http response header
// remainder of header follows below, depending on if
// web page or XML page is requested
// Ajax request - send XML file
if (StrContains(HTTP_req, "ajax_inputs")) {
// send rest of HTTP header
client.println("Content-Type: text/xml");
client.println("Connection: keep-alive");
client.println();
// print the received text to the LCD if found
if (GetLcdText(lcd_buf_1, lcd_buf_2, LCD_BUF_SZ)) {
// lcd_buf_1 and lcd_buf_2 now contain the text from
// the web page
// write the received text to the LCD
lcd.clear();
lcd.print(lcd_buf_1);
lcd.print(lcd_buf_2);
else { // web page request
client.println("Content-Type: text/html");
client.println();
// send web page
webFile = SD.open("index.htm"); // open web page file
if (webFile) {
while(webFile.available()) {
client.write(webFile.read()); // send web page to client
webFile.close();
// reset buffer index and all buffer elements to 0
req_index = 0;
StrClear(HTTP_req, REQ_BUF_SZ);
// every line of text received from the client ends with \r\n
if (c == '\n') {
// last character on line of received text
// starting new line with next character read
else if (c != '\r') {
// a text character was received from client
currentLineIsBlank = false;
} // end if (client.available())
} // end while (client.connected())
delay(1); // give the web browser time to receive the data
client.stop(); // close the connection
} // end if (client)
// get the two strings for the LCD from the incoming HTTP GET request
boolean GetLcdText(char *line1, char *line2, int len)
boolean got_text = false; // text received flag
char *str_begin; // pointer to start of text
char *str_end; // pointer to end of text
int str_len = 0;
int txt_index = 0;
char *current_line;
current_line = line1;
// get pointer to the beginning of the text
str_begin = strstr(HTTP_req, "&L1=");
for (int j = 0; j < 2; j++) { // do for 2 lines of text
if (str_begin != NULL) {
str_begin = strstr(str_begin, "="); // skip to the =
str_begin += 1; // skip over the =
str_end = strstr(str_begin, "&");
if (str_end != NULL) {
str_end[0] = 0; // terminate the string
str_len = strlen(str_begin);
// copy the string to the buffer and replace %20 with space ' '
for (int i = 0; i < str_len; i++) {
if (str_begin[i] != '%') {
if (str_begin[i] == 0) {
// end of string
else {
current_line[txt_index++] = str_begin[i];
if (txt_index >= (len - 1)) {
// keep the output string within bounds
else {
// replace %20 with a space
if ((str_begin[i + 1] == '2') && (str_begin[i + 2] == '0')) {
current_line[txt_index++] = ' ';
i += 2;
} // end for i loop
current_line[txt_index] = 0;
if (j == 0) {
// got first line of text, now get second line
str_begin = strstr(&str_end[1], "L2=");
current_line = line2;
txt_index = 0;
got_text = true;
} // end for j loop
return got_text;
// sets every element of str to 0 (clears array)
void StrClear(char *str, char length)
for (int i = 0; i < length; i++) {
str[i] = 0;
// searches for the string sfind in the string str
// returns 1 if string found
// returns 0 if string not found
char StrContains(char *str, char *sfind)
char found = 0;
char index = 0;
char len;
len = strlen(str);
if (strlen(sfind) > len) {
return 0;
while (index < len) {
if (str[index] == sfind[found]) {
found++;
if (strlen(sfind) == found) {
return 1;
else {
found = 0;
index++;
return 0;
index.htm.txt (1.18 KB)
