Hello, I am trying to get the the latitude and longitude from my GPS and store it in a cloud variable.
This is the example code I'm using:
#include "thingProperties.h"
#include <NMEAGPS.h>
#include <GPSport.h>
#include <Streamers.h>
static NMEAGPS gps;
static gps_fix fix;
double latitude;
double longitude;
static void doSomeWork()
trace_all( DEBUG_PORT, gps, fix );
static void GPSloop()
while (gps.available( gpsPort ))
fix = gps.read();
doSomeWork();
DEBUG_PORT.begin(9600);
delay(1500);
initProperties();
ArduinoCloud.begin(ArduinoIoTPreferredConnection);
setDebugMessageLevel(2);
ArduinoCloud.printDebugInfo();
while (!DEBUG_PORT);
DEBUG_PORT.print( F("NMEA.INO: started\n") );
DEBUG_PORT.print( F(" fix object size = ") );
DEBUG_PORT.println( sizeof(gps.fix()) );
DEBUG_PORT.print( F(" gps object size = ") );
DEBUG_PORT.println( sizeof(gps) );
DEBUG_PORT.println( F("Looking for GPS device on " GPS_PORT_NAME) );
#ifndef NMEAGPS_RECOGNIZE_ALL
#error You must define NMEAGPS_RECOGNIZE_ALL in NMEAGPS_cfg.h!
#endif
#ifdef NMEAGPS_INTERRUPT_PROCESSING
#error You must *NOT* define NMEAGPS_INTERRUPT_PROCESSING in NMEAGPS_cfg.h!
#endif
#if !defined( NMEAGPS_PARSE_GGA ) & !defined( NMEAGPS_PARSE_GLL ) & \
!defined( NMEAGPS_PARSE_GSA ) & !defined( NMEAGPS_PARSE_GSV ) & \
!defined( NMEAGPS_PARSE_RMC ) & !defined( NMEAGPS_PARSE_VTG ) & \
!defined( NMEAGPS_PARSE_ZDA ) & !defined( NMEAGPS_PARSE_GST )
DEBUG_PORT.println( F("\nWARNING: No NMEA sentences are enabled: no fix data will be displayed.") );
#else
if (gps.merging == NMEAGPS::NO_MERGING)
DEBUG_PORT.print ( F("\nWARNING: displaying data from ") );
DEBUG_PORT.print ( gps.string_for( LAST_SENTENCE_IN_INTERVAL ) );
DEBUG_PORT.print ( F(" sentences ONLY, and only if ") );
DEBUG_PORT.println( F(" is enabled.\n"
" Other sentences may be parsed, but their data will not be displayed.") );
#endif
DEBUG_PORT.print ( F("\nGPS quiet time is assumed to begin after a ") );
DEBUG_PORT.println( F(" sentence is received.\n"
" You should confirm this with NMEAorder.ino\n") );
trace_header( DEBUG_PORT );
DEBUG_PORT.flush();
gpsPort.begin( 9600 );
ArduinoCloud.update();
GPSloop();
latitude = fix.latitudeL();
longitude = fix.longitudeL();
location = {latitude, longitude};
I can't figure out how to display the coordiantes on to the dashboard.
