Displaying the Minimum Value
Hello everyone.
I'm working on a project for a class of mine and it involves Arduino. I'm having a little difficulty writing some code and was hoping someone could help me.
The project is a distance sensor. I have a Ultrasonic sensor attached to a servo motor. Right now when I press a button, the servo pans around and the ultrasonic reads distance from objects. The distance is displayed on an LCD screen.
Here's what I'm trying to do next. After the motor pans arounds, I want the system to display the the shortest distance the sensor read while it was panning. Here's a copy of my code so far.
 #include <LiquidCrystal.h>
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
const int pingPin = 7;
#include <Servo.h>
Servo myservo;
int pos = 0;
const int scanButton = 9;
int buttonState = 0;
  pinMode(scanButton, INPUT);
  myservo.attach( 8 );
  buttonState=digitalRead(scanButton);
  if (buttonState==HIGH)
    delay(1500);
    for(pos = 0; pos < 100; pos +=1)
      myservo.write(pos);
      delay(34);
      long duration, inches;
      pinMode(pingPin, OUTPUT);
      digitalWrite(pingPin, LOW);
      delayMicroseconds(2);
      digitalWrite(pingPin, HIGH);
      delayMicroseconds(5);
      pinMode(pingPin, INPUT);
      duration = pulseIn(pingPin, HIGH);
      inches = microsecondsToInches(duration);
      lcd.begin(16, 2);
      lcd.print("Dist: ");
      lcd.print(inches);
      lcd.print(" in");
    delay(2500);
    for(pos = 100; pos>=1; pos -=1)
      myservo.write(pos);
      delay(35);
      inches = (microsecondsToInches(duration));
      lcd.begin(16, 2);
      lcd.print(inches);
      lcd.print(" in");
    myservo.write(pos);
long microsecondsToFeet(long microseconds)
  return microseconds / 876 / 2;
long microsecondsToInches(long microseconds)
  return microseconds / 74 / 2;
Any help would be great! Thank you!
Moderator edit:
</mark> <mark>[code]</mark> <mark>
</mark> <mark>[/code]</mark> <mark>
tags added.
A simple way is create a variable , take your first distance reading, store it, take 2nd reading if lower than the variable replace the variable and so on. You may want to store the servo location also, so that you point to the closest object
jasit:
What function would I use to do that?
I would do it like this
set minDistance to 9999
start for loop
  move servo to angle
  take a distance reading
  if reading less than minDistance
    minDistance = reading
  end if
  move servo
end for loop
//minDistance now holds the minimum distance recorded
Incidentally, your code would be much neater if you put the distance measuring and distance display code in functions and called them when required in each for loop.
