I'm new to Arduino, but I've been working with java for the past five years as a hobby.
I want to read two analog sending units, both have voltages ranging from 0-5 volts, and display their output onto a 4.3" (480x272) LCD.
My questions are:
Is this a feasible task to write entirely in Java?
Can data be read from the input at a rate of 500ms, possibly faster?
What are the limitations of the video out? I'm thinking of using composite out. Is a graphically pleasing interface possible?
Are there graphic libraries (other than TFT library)?
I can only find very basic 8-bit looking examples online.
Yea its possible but you wont be able to write it in java, it will need to be in C/C++.
It can read the data a lot fast then that if you need it to.
You may want to look into the TVOut library, but it wont be in color. Or you can get a TFT lcd and make your own interface. I have a code that already allows you to make a working gauge, but it will require you to have a TFT that uses the UTFT graphics library.
HazardsMind:
I've looked around at these screens and the only ones I can find only the stand alone lcd. Do they make cases? I'd like to be able to mount it.
SantaCruz:
I've made "analog" displays on VFD displays. The idea is simple: Just convert your data to an angle. For example, if your data ranges from 0 to 255, convert that to something like -60 degrees to +60 degrees (angle).
Then take the sine of the angle times the radius (radius is the length of the gauge "needle"). Same with the cosine of the angle.
This is a polar to rectangular conversion, and it gives you the X and Y coordinates for the END point of a line. The START point of the line will be, of course, always in the same spot.
Then erase an old line and draw a new one each time the data changes. You now have a "gauge" who's "needle" swings a total arc of 120 degrees.
Finally draw an arc with tick marks for the gauge legend and you've got a meter.
A horizontal or vertical "tape meter" type of display is even easier. Just draw a long, skinny rectangle with tick marks as the legend, then erase and draw a line or a box who's horizontal or vertical position is relative to the data.
This is, of course, for a bitmap type of display. If you're using a "TV type" of display that uses video, then the above does not apply.
