Morning all
I am trying to get a GPS unit (GT-U7) and a BME888 (temp and pressure) unit on the same program but am running into issues. I can get they both working individually but when I combine the programs they stop functioning. Could anyone suggest what I might be doing wrong, from what I can work out it is when I add in the second Serial call for data for the GPS.
Program below, thanks.
#include <Wire.h>
#include <Adafruit_Sensor.h>
#include "Adafruit_BME680.h"
#include <SPI.h>
#include <SD.h>
#include <SoftwareSerial.h>
#include <FuGPS.h>
#define SoftTX 2
#define SoftRX 3
SoftwareSerial SerialSoft(SoftRX, SoftTX); // RX, TX
FuGPS fuGPS(SerialSoft);
#define SEALEVELPRESSURE_HPA (1013.25)
Adafruit_BME680 bme; // Create a BME680 sensor object for I2C
while (!Serial);
Serial.println(F("BME680 test"));
if (!bme.begin()) {
Serial.println("Could not find a valid BME680 sensor, check wiring!");
while (1); // Stay in a loop if the sensor is not found
//delay(1000);
//Serial.println("");
//SerialSoft.begin(9600);
//delay(5000);
// Configure sensor settings
bme.setTemperatureOversampling(BME680_OS_8X);
bme.setHumidityOversampling(BME680_OS_2X);
bme.setPressureOversampling(BME680_OS_4X);
bme.setIIRFilterSize(BME680_FILTER_SIZE_3);
bme.setGasHeater(320, 150); // 320°C for 150 ms
delay(2000);
pressure();
//GPS();
void pressure(){
// Check if the BME680 sensor reading was successful
if (!bme.performReading()) {
Serial.println("Failed to perform reading :(");
return;
// Display temperature in degrees Celsius
Serial.print("Temperature = ");
Serial.print(bme.temperature);
Serial.println(" °C");
// Display pressure in hPa (hectopascals)
Serial.print("Pressure = ");
Serial.print(bme.pressure / 100.0);
Serial.println(" hPa");
// Display humidity in percentage
Serial.print("Humidity = ");
Serial.print(bme.humidity);
Serial.println(" %");
// Calculate Dew Point
float dewPoint = bme.temperature - ((100 - bme.humidity) / 5);
Serial.print("Dew Point = ");
Serial.print(dewPoint);
// Display gas resistance in KOhms
Serial.print("Gas = ");
Serial.print(bme.gas_resistance / 1000.0);
Serial.println(" KOhms");
// Calculate and display approximate altitude
Serial.print("Approx. Altitude = ");
Serial.print(bme.readAltitude(SEALEVELPRESSURE_HPA));
Serial.println(" m");
// Print a blank line for better readability
// Delay for 2 seconds before the next reading
delay(2000);
GPS();
void GPS(){
if (fuGPS.read())
Serial.print("Quality: ");
Serial.println(fuGPS.Quality);
Serial.print("Satellites: ");
Serial.println(fuGPS.Satellites);
if (fuGPS.hasFix() == true)
//Data from GGA message
Serial.print("Accuracy (HDOP): ");
Serial.println(fuGPS.Accuracy);
Serial.print("Altitude (above sea level): ");
Serial.println(fuGPS.Altitude);
Serial.println("Date:"+String(fuGPS.Days)+"-"+String(fuGPS.Months)+"-20"+String(fuGPS.Years)+" "+String(fuGPS.Hours)+":"+String(fuGPS.Minutes)+":"+String(fuGPS.Seconds));
Serial.println("Latitude: " + String(fuGPS.Latitude, 6) + ", Longitude: " + String(fuGPS.Longitude, 6));
