Displaying two separate values at same time to 4 digit 7 segment display
I am trying to display two separate values on the one Adafruit 7 Segment LED Backpack Display at the same time. What I have is a temperature value (0-99) and a humidity value (0-99). I want the Temperature to be shown on the first two digits and the Humidity on the second two digits. For simplicity, if I have a value of, say, t=23 and a value of h=67, how can I make the display show 2367?
Hoping someone can help.
Please, post a picture of your 4-digit display unit and also the type of Arduino (UNO, NANO, MEGA).
You may follow this link.
(23 * 100) + 67 = 2367
Use (t * 100) + h to get the number to show on the display.
That is brilliantly simple!. Thank You.
Problem Solved by post#3 (odometer). Thank You.
We would like to see your codes/sketch and the connection diagram.
Project is still in progress, it will display temp/humidity (outside) using a Platinum RTD Sensor & Honeywell HIH-4030. It will also display temp/humidity (inside) using a BME680 board, plus display the air pressure and min/max temperatures over the last 24 hrs, so there will be a total of 4, 1.2", 4 digit, 7 segment Led displays. The plan is to mount it inside a Shadow Box Photo Frame, so there is much to do before wiring diagrams and sketches are completed.
