Displays...
I´m looking for a big graphic display (around 3'') with a wide temperature operation. It has to be Sunlight Readable. It will be in a bike. I´m thinking in a 4D System or GLDC (KS0108 or T6963). I would like something with controller,because I would like to control with Mega.
¿Any recommendation? I´ve looking CrystalFonz displays... If it´s possible with color feature, it´ll be fantastic...
Thank you
Regards,
Igor R.
Also I´ve found eDIP => http://www.lcd-module.com/products.html
Have someone use it?
According to this Mouser page, those things are 300 dollars: http://www.mouser.com/Search/Refine.aspx?Keyword=790-EDIPTFT43-A
Have you had a look at the LiquidWare TouchShield Slide: http://www.liquidware.com/shop/show/TSL/TouchShield+Slide
Exist others cheaper, it depends of the model...
I´m not sure that a TFT or Oled will be sunlight redeable...When I try to see something in my PDA outside, it´s difficult...
It will be fitted on a motorbike... I need something redeable with high bright, wide temperature range and the electronic inside must resist vibrations.
Graphics LDC are the best in price... for sure....But nowadays are quite "retro" design.....je,je,je :D
OLED is sun readable.
And what about life of this technologies? Because I´ve read that Oled are 20k hours...
Are you expecting to run your bike for that many hours? If you average 25 miles per hour you would be able to travel a distance greater then that to the moon and back before you used up the 20k hours.
It used to be that the blue's had a life of about 20k hours but nowadays the blue is more like 40k hours and the other colours much higher. It depends if you go for a decent display or not... Depends on price a little bit.
Anyway, what's wrong with a dot graphic display? who doesn't like a bit of retro? 8-)
For temperature you could just use a 20x4 display and use some 4 line text for BIG NUMBERS...
Mowcius
Mem,You don´t have to think only in application with the motorbike in movement.... There are 2'3 years... You imagine that the display of your car break down in 5 years .... ;)
It´s not to show temperature... I need that the display works in a wide range of temperature... like -20 to 80ºC.
The application will be like an onboard computer.... ;)
Of course, with a gldc an a little of design could be something cool
20k operating hours in my car would take 60 years ;)
Anyway, if you do decide to go retro, I have a nice GLCD library for you to use: http://www.arduino.cc/playground/Code/GLCDks0108 :)
Thank you mem. But I´m asking more about models, types, where to buy, experiences, ....
I need a big one display (more than 3'')
Regards,
Oh, sorry, misread the post,
sounds like a cool project,
Mowcius
Normal commercial electronics is only specked for 0 to 70C. Going outside these ranges costs you a lot more. A military specified display is going to cost about 5 to 10 times more than a commercial display.
I´ve found CrytalFontz which has -20 to 70ºC. With T6963 controller and 160x128 (101 x 82 mm). It seems good!!
Any experience with this company? Another similar?
One easy question:
How can I calculate the space require to store a bitmap in a dot graphic display?
For example, if I have a display of 128x64 dots
Kind Regards,
Igor R.
total bytes equals width times height times bits per pixel divided by 8
128 x 64 with 8 bits (1 byte) per pixel is 8k bytes
Thank you mem!!!
Anyone knows which is the LCD and touch used in LCDash project? (Megasquirt)
It´s a T6963. I´m asking about where I can buy it.
http://lcdash.wikispaces.com/LCD http://lcdash.wikispaces.com/touchscreen
Regards,
Why 8 bits per pixel if this is a monochrome display?
In the first post the OP said he would ideally like a color display if possible
