disrupting loop
Hello everyone Im new to Arduino and the language used and would like to learn more,
That being said Id love to be able controll my setup of gate motor and can't find (lack of knowlage) something to interupt the loop and return to openGate
here is the code
const int buttonPin = 10; // Give pin 10 a constant name
const int openGate = 13; // Give pin 13 a constant name
const int closeGate = 12; // Give pin 12 a constant name
int buttonState = 0; // Give varable button a state value
	pinMode(openGate, OUTPUT); // Make pin 13 an output
	pinMode(closeGate, OUTPUT); // Make pin 12 an output
	pinMode(buttonPin, INPUT); // Make pin 10 an input
	buttonState = digitalRead(buttonPin); // Read button value or state
	if (buttonState == HIGH){
	digitalWrite(openGate, HIGH);
	delay(2000);
	digitalWrite(closeGate, HIGH); // Ill like to have it on button press to return to (openGate, HIGH)
	delay(2000);
	else{
	digitalWrite(openGate, LOW);
	digitalWrite(closeGate, LOW);
You've got four seconds of delays in there - if you want to respond to a button press, get rid of them.
Look at the blink without delay example for clues.
Please remember to use code tags when posting code.
Thanx will look into the blink without delay sketch
And once again, the boilerplate question when I see "pinMode(pin,INPUT) then,
"if(digitalRead(pin) == HIGH)".
Do you have a pulldown resistor connected from GND to the input pin?
yes 10kilo ohm to ground if depressed will make pin 10 low
thanx for asking luckily I'm testing everything on https://circuits.io before anything will be connected to my recently received Arduino
okay done away with delay function how do I now interrupt the unsigned long currentMillis = millis(); function could you point me in the right direction please?
The demo Several Things at a Time is an extended example of BWoD and illustrates the use of millis() to manage timing. It may help with understanding the technique.
Note how everything is done a little at a time so that there are opportunities to do other things.
...R
Oh thanx this will definitely help me thanx a million
If I understand what you want the first button press opens the gate and the next closes it.
If that is correct you need to keep track of whether the gate is open or closed. When the button is pressed open it if it's closed or else close it.
I added a boolean variable gateIsOpen to your code to show you what I mean, but I'm not sure how your setup works so you should change it as necessary.
boolean gateIsOpen = false;    // true => gate is open
    // if gate is open
    if( gateIsOpen )
      // close it
      // open it
    } // else
    // set flag to reflect current state
    gateIsOpen = !gateIsOpen;
  else{
But after 2 seconds, turn off the open/close motor.
so there's four states: OPENING, CLOSING, OPENED, CLOSED.
This kind of thing:
const byte buttonPin = 10; // Give pin 10 a constant name
const byte openGatePin = 13; // Give pin 13 a constant name
const byte closeGatePin = 12; // Give pin 12 a constant name
enum State {
  CLOSED, OPENING, OPEN, CLOSING
} state = CLOSED;
uint32_t startMotorMs;
int buttonState = HIGH;
  pinMode(openGatePin, OUTPUT); // Make pin 13 an output
  pinMode(closeGatePin, OUTPUT); // Make pin 12 an output
  pinMode(buttonPinPin, INPUT); // Make pin 10 an input
  int prevButtonState = buttonState;
  switch (state) {
    case CLOSED:
      if (prevButtonState = HIGH && buttonState == LOW) {
        startMotorMs = millis();
        digitalWrite(openGatePin, HIGH);
        state = OPENING;
    case OPENING:
        digitalWrite(openGatePin, LOW);
        digitalWrite(closeGatePin, HIGH);
        state = OPENING;
      else if (millis() - startMotorMs >= 2000 ) {
        state = OPEN;
    case OPEN:
        state = CLOSING;
    case CLOSING:
        digitalWrite(closeGatePin, LOW);
        state = OPENING;
        state = CLOSED;
Not exactly what id like is if the button is pressed the gate fully opens stays open for x amount time then closes but upon closing either the button or if installed I/R should interrupt the process by restarting the loop over again if not it should return to zero and listen to button pressed.
at the end of the day Id like to use my Arduino to open both my gates using the same method using different pins (and sensors ) of coarse
I must add the motors is normal dc12volt not stepper motors and the closing and opening times can be set for exactly the time it takes to open and close I can always add a normally closed switch in line with the motors if the time is too high the switches will break the connection stopping the motors instantly both is pin and crown gear boxed type and very slow
Seems like doesn't matter what I do ill have to have more inputs (switches) to declare current state?
Here is my project https://circuits.io/circuits/3166099-gate-motor if anyone has a different approach id love to hear?
HannesWallace:
No, I don't think you need more switches. You have a switch that's activated when fully open and another when fully closed. That defines three states that you can measure in the world. (Actually there's a fourth: the error state when both switches are activated at the same time.)
The rest of it is just internal memory inside the Arduino. If the gate was open and we started driving the motor to the 'closed' position but it hasn't yet activated the closed switch, then we are in the CLOSING state. If you have been in the CLOSING state more than 90 seconds and it hasn't yet got to CLOSED then there's probably some error, so stop.
Adding a 5-minute timeout on the OPEN state is also relatively easy - just more items to remember in software. Remember when it reached OPEN, then if it's still in OPEN after 300000 milliseconds, start closing.
It looks like perhaps you built that circuit on circuits.io by using the 'breadboard' view. Please don't do that. You are just making it difficult for yourself. Use the schematic view. Then you can make the 4 transistors look like a conventional H-bridge. For me looking at that circuit, I can't tell if you have actually wired an H-bridge or something else.
Oh - I thought that there were two buttons: one to open the gate and one to close it.
Still, you can see how the "state machine" pattern works, I hope. If you want to use bump sensors rather than timings, then yes you will need two bump sensors (buttons) as well as the 'gate open!' button itself.
PaulMurrayCbr:
That would make life a lot simpler. Is there any reason not to have two buttons?
...R
Robin2:
Basically - that's not what he wants his machine to do. He wants a button that opens the gate, hold it open for a couple of seconds, then closes it again.
It's really not any more complicated than the two-button thing.
PaulMurrayCbr:
I know. But I was asking WHY?
...R
Seems there is a discusion on how it needs to work
Here is my code (well a work in progress)
const int remote = 2;
const int openedBtn = 3;
const int closedBtn = 4;
const int errLed = 7;
const int closeRl = 12;
const int openRl = 13;
int remoteState = LOW;
int openedBtnState = LOW;
int closedBtnState = LOW;
int errLedState = LOW;
int closeRlState = LOW;
int openRlState = LOW;
unsigned long tslr = 0;
long interval_open = 10000;
long interval_close = 10000;
long interval_pause = 20000;
void setup () {
  pinMode(remote, INPUT);
  pinMode(openedBtn, INPUT);
  pinMode(closedBtn, INPUT);
  pinMode(errLed, OUTPUT);
  pinMode(closeRl, OUTPUT);
  pinMode(openRl, OUTPUT);
  boolean errLed = false;
  delay(100);
  Serial.println("GATE PROGRAM STARTED");
 tslr = millis();
  remoteState = digitalRead(remote);
  openedBtnState = digitalRead(openedBtn);
  closedBtnState = digitalRead(closedBtn);
  errLedState = digitalRead(errLed);
  closeRlState = digitalRead(closeRl);
  openRlState = digitalRead(openRl);
if(remoteState == LOW){
  digitalWrite(openRl, LOW);
  Serial.println("WAITING FOR REMOTE INPUT");
}else if(remoteState == HIGH){
    digitalWrite(openRl, HIGH);
    Serial.println("GATE OPENING NOW");
    while((millis() - tslr) < interval_open);
  }else if(openedBtnState == LOW){
      Serial.println("OPENING ERROR");
      while(1){}
    }else if(openedBtnState == HIGH){
        tslr = millis();
        Serial.println("GATE OPENED WAITING FOR CAR");
        while((millis() - tslr) < interval_pause);
        tslr = millis();
        digitalWrite(closeRl, HIGH);
        Serial.println("CLOSING GATE NOW");
        while((millis() - tslr) < interval_close);
      }else if(closedBtnState == LOW){
          digitalWrite(errLedState, HIGH);
          Serial.println("CLOSING ERROR");
        }else{
and the project is being tested here
Hope you guys Understand now
Okay I've managed to compile code that checks out in compiler but when uploaded to board does not work also would like to add a interrupt button when the loop reaches the closing state bypasses and goes to opening state any help will be greatly appreciated
const byte remote = 2;                                             // Give pin 2 a constant name
const byte openRl = 13;                                            // Give pin 13 a constant name
const byte closeRl = 12;                                           // Give pin 12 a constant name
const byte closedBtn = 11;                                         // Give pin 11 a constant name
const byte openedBtn = 10;                                         // Give pin 10 a constant name
const byte errLed = 9;                                             // Give pin 9 a constant name
enum State {                                                       // Call state function
  CLOSED, OPENING, OPEN, CLOSING                                   // Give program possible states
} state = CLOSED;                                                  // Set the gate to a closed state
unsigned long tslr = 0;                                            // Call timer function
long interval_opening = 10000;                                     // Create timer for opening state
long interval_closing = 10000;                                     // Create timer for closing state
long interval_pausing = 20000;                                     // Create timer for pausing/opened state
  pinMode(remote, INPUT);                                          // Make pin 2 an input
  pinMode(openRl, OUTPUT);                                         // Make pin 13 an output
  pinMode(closeRl, OUTPUT);                                        // Make pin 12 an output
  pinMode(closedBtn, INPUT);                                       // Make pin 11 an input
  pinMode(openedBtn, INPUT);                                       // Make pin 10 an input
  pinMode(errLed, OUTPUT);                                         // Make pin 9 an output
  Serial.begin(9600);                                              // Begin serial monitor for fault finding
  delay(150);                                                      // Delay program so monitor can connect
  boolean errLed = LOW;
  Serial.println("Program Loaded!");
remoteState = digitalRead(remote);                                 // Tell loop how to get remote state
openedBtnState = digitalRead(openedBtn);                           // Tell loop how to get opened button state
closedBtnState = digitalRead(closedBtn);                           // Tell loop how to get closed button state
errLedState = digitalRead(errLed);                                 // Tell loop how to get error led state
closeRlState = digitalRead(closeRl);                               // Tell loop how to get close relay state
openRlState = digitalRead(openRl);                                 // Tell loop how to get open relay state
int prevRemoteState = remoteState;                                 // Tell loop where to get previos remote state
  switch (state) {                                                 // Tell loop what the enum state is
    case CLOSED:                                                   // Switch state to closed
      if (remoteState == HIGH) {                                   // Look for remote state change
        tslr = millis();                                           // Get time form timer
        while((millis() - tslr) < interval_opening);               // Tell loop to use open interval
        digitalWrite(openRl, HIGH);                                // Tell open relay to close
        Serial.println("OPENING GATE NOW!");                       // Tell serial what to display
        state = OPENING;                                           // Switch state of gate to opening
      else if(remoteState == LOW){
        Serial.println("WAITING FOR INPUT FROM REMOTE");
        return;
      else if (openedBtn == HIGH) {                                // Tell loop to pause while opened
        while((millis() - tslr) < interval_pausing);               // Tell loop to use pauseing interval
        digitalWrite(openRl, LOW);                                 // Tell open relay to open
        Serial.println("GATE OPENED!");                            // Tell serial what to display
        state = OPEN;                                              // Switch state of gate
      else if(openedBtn == LOW) {
        digitalWrite(errLed, HIGH);                                // Light up error led
        Serial.println("ERROR OPEN BUTTON NOT HIGH");              // Tell serial what to display
        errLed == HIGH;
        while(1){}                                                 // Stop loop here and wait for reset
    case OPEN:                                                      // Tell loop what the enum state is
      if (prevRemoteState = LOW && remoteState == HIGH) {           // Look for remote state change
        digitalWrite(closeRl, HIGH);                                // Tell open relay to close
        Serial.println("GATE OPENED WAITING FOR PAUSE TO EXPIRE!"); // Tell serial what to display
        state = CLOSING;                                            // Switch state of gate
    case CLOSING:
      if (prevRemoteState = HIGH && remoteState == LOW) {           // Tell loop what the enum state is
        digitalWrite(closeRl, HIGH);                                // Tell close relay to close
        digitalWrite(openRl, LOW);                                  // Tel open relay to open
        Serial.println("GATE CLOSING NOW");                         // Tell serial what to display
       else {                                                       // Tell loop to pause while opened
        Serial.println("GATE OPENED WAITING FOR PAUSETO EXPIRE!");  // Tell serial what to display
        state = OPEN;
It seems to me unlikely that the processor isn't running, so if it is, it can be said to be working.
If so, it should be generating debug messages.
But you haven't posted any of those.
