I'm new to this and I'm trying to find out if my idea is feasible. I found similar ideas but not quite the same, so I'd appreciate if you guys can help me with this one.
I need to know when two objects have a specific distance between each other ( 5, 10 or 15 meters ). I need to know when they are within this range and when they are not anymore. Those two objects will be moving at a reasonable speed ( between 20km/h and 50km/h ) and there will be no obstacles between them. The object in the front doesn't need to know about the object in the back, but the object in the back must know about the object in the front and if they are side by side. Something similar to a car race when the car in the back is going to overtake the car in the front. I need to know when the car in the back is within the desired range and when the overtaking is finished.
I read about lasers, sonic sensors, gps, RF, etc but so far no idea if this is feasible or not and if it is what is the best solution.
There are people who've got that sort of thing working by doing video analysis and moving object recognition and tracking, but it needs a fair amount of work to develop and q lot of processing power to execute it. That approach is definitely not an Arduino project. I don't think an ultrasonic sensor is going to be feasible in the environment you describe, and I can't see any other way to achieve it.
The "seeker" sends a "ping" - a short ultrasound burst - and the "target" responds with two bursts.
The distance is calculated by the transit time, but only if the two received bursts are the correct distance apart. Thus it only responds to "echoes" that are actually from the target, and can handle far more attenuation than if it was looking for a passive echo, so can also use less power and/ or a wider beam.
Paul__B, this seems like it would be a viable way to do this, but I haven't seen any projects that actually use ping sensors between two Arduinos. They always use the reflection. It seems like you could get a lot greater distance by using the pings directly instead of reflections. Does anyone know of a project that uses this idea?
TanHadron:
Precisely my point - much greater signal gain that can be shared between a wider beam width, increased range, greater discrimination from ambient noise and possibly, reduced power,
TanHadron:
Not I, but it should be simply a matter of adapting present ultrasonic ranging approaches.
You could also do a transponder-like approach with a strobe (probably IR) which is triggered at the same time as the ultrasound pulse.
Time-of-flight of the IR pulse is negligible.
