Distance measurement - need an alternative to sharp ir and ultrasound
Hi! I need to know if there is a way to measure distance without the use of infrared and ultrasonic? The range will be between 3cm to 5m with +-1cm of accuracy and it needs to be fast. I am building soccer robots which track a ball with infrared light. So I can't used Sharp IR sensors because of interference or ultrasound sensors as they are too slow. Something very similar to the Sharp IR would be awesome!
I was looking into laser range sensors but have not had any luck with finding any.
Big budget lasers - http://www.robotshop.com/high-end-lasers-obstacle-detectors.html?lang=en-us -
haven't seen low budget laser (build your own?)
other IR ? - http://www.robotshop.com/productinfo.aspx?pc=RB-Cyt-75&lang=en-US -
depending on the colour of the ball, maybe line following sensors can detect the ball? - http://www.robotshop.com/productinfo.aspx?pc=RB-Plx-236&lang=en-US -
NeoStark: Hi! I need to know if there is a way to measure distance without the use of infrared and ultrasonic? The range will be between 3cm to 5m with +-1cm of accuracy and it needs to be fast. I am building soccer robots which track a ball with infrared light. So I can't used Sharp IR sensors because of interference or ultrasound sensors as they are too slow. Something very similar to the Sharp IR would be awesome!
Ultrasonic can sense distance 30 times a second. Do you need it to be faster than that?
Tim
