I would like to measure two distances with the Ultrasonic PING Sensor (Parallax 28015) on the same Arduinoboard.
My goal: Detecting a person at the distances between A) 50cm - 80cm and also at B) 100cm - 120cm. I like to have two seperate digital outputs (high, 5V) for the cases A and B.
there are lots of people in the forum who are better at code than I am, but here's my two cents!
I think you would want something like this, in very rough pseudo code (i.e. fill in the blanks). Check the reference pages to see how to write the boolean conditions in the IF loops. You'll also have to record the sensor values for the IF loops: test to see what value the sensor returns for each of your distance limits.
void loop(){
take sensor reading; // read the sensor
// test to see if the sensor value is in position A range
if sensorValue (between position A minimum and maximum);{
digitalWrite(positionApin, HIGH); // set A pin high if sensor in range
else { // set A pin low if sensor not in range
digitalWrite(positionApin, LOW);}
// test to see if the sensor value is in position B range
if sensorValue (between position B minimum and maximum){
digitalWrite(positionBpin, HIGH); // set B pin high if sensor in range
else { // set B pin low if sensor not in range
digitalWrite(positionBpin, LOW);}
Hi!
I have modified the code with if/else... and some () and it works!
Thanks a lot
/* Ultrasound Sensor
* Reads values (00014-01199) from an ultrasound sensor (3m sensor)
* and writes the values to the serialport.
* http://www.xlab.se | http://www.0j0.org
* copyleft 2005 Mackie for XLAB | DojoDave for DojoCorp
* extended 02.01.2007 by aktor
* used for PING Ultrasonic Range Finder (#28015 from Parallax)
* detection of two distance ranges for two digital outputs
int ultraSoundSignal = 7; // Ultrasound signal pin
int val = 0;
int ultrasoundValue = 0;
int timecount = 0; // Echo counter
int ledPin1 = 13; // LED at digital pin 13
int ledPin2 = 10; // LED at digital pin 10
beginSerial(9600); // Sets the baud rate to 9600
pinMode(ledPin1, OUTPUT); // Sets the digital pin 13 as output
pinMode(ledPin2, OUTPUT); // Sets the digital pin 10 as output
timecount = 0;
val = 0;
pinMode(ultraSoundSignal, OUTPUT); // Switch signalpin to output
/* Send low-high-low pulse to activate the trigger pulse of the sensor
digitalWrite(ultraSoundSignal, LOW); // Send low pulse
delayMicroseconds(2); // Wait for 2 microseconds
digitalWrite(ultraSoundSignal, HIGH); // Send high pulse
delayMicroseconds(5); // Wait for 5 microseconds
digitalWrite(ultraSoundSignal, LOW); // Holdoff
/* Listening for echo pulse
pinMode(ultraSoundSignal, INPUT); // Switch signalpin to input
val = digitalRead(ultraSoundSignal); // Append signal value to val
while(val == LOW) { // Loop until pin reads a high value
while(val == HIGH) { // Loop until pin reads a high value
timecount = timecount +1; // Count echo pulse time
/* Writing out values to the serial port
ultrasoundValue = timecount; // Append echo pulse time to ultrasoundValue
serialWrite('A'); // Example identifier for the sensor
printInteger(ultrasoundValue);
serialWrite(10);
serialWrite(13);
/* Lite up LED if the timevalues passed by the echo pulse (distances mesured an compared as dispayed on the serial monitor)
//LED1 ON, Pin13, distances 70cm - 85cm
if((timecount < 510) && (timecount > 440)){
digitalWrite(ledPin1, HIGH);
digitalWrite(ledPin1, LOW);
//LED2 ON, Pin10, distance 15cm - 30cm
if((timecount < 190) && (timecount > 100)){
digitalWrite(ledPin2, HIGH);
digitalWrite(ledPin2, LOW);
/* Delay of program
delay(100);
int val = 0;
timecount = 0;
val = 0;
serialWrite(10);
serialWrite(13);
//LED1 (GREEN) ON, Pin13, distances high
if((timecount <= 1300) && (timecount >= 1100)){
delay(1200); // waits for a second
//LED2 (RED) ON, Pin10, distance low
if((timecount <= 900) && (timecount >= 700)){
delay(1300); // waits for a second
/* Delay of program
delay(400); //orig 100
I recently made some code for the srf04 and the PING))). I think if you use the pulseIn function, you can get better resolution on the sensor. Here is an example.
the constant you are looking for is 0.03434, for instructions on how to use it I will direct you to the page that I reference (it's a pdf, so you can download and save it)
Question, that pdf that eustace referenced seems to indicate that a pulse width is 29.033 uS per centimeter and 73.746 uS per inch(comments on page 10 for the Javelin). So wouldn't ((pulselength / 73.746)/2) work? It seems to be pretty close when comparing a wall @ 80" with the serial spew and a tape measure.
