Distance Sensor and MIDI CC issues
Hello,
I realize this has been discussed at length in other posts however I can't seem to find one that fits this exact scenario - in terms that I'm understanding.
I am attempting to use a sparkfun ultrasonic sensor (HC-SR04) to send MIDI CC values via middleware (hairless MIDI) to ableton/Max.
I've examined my code carefully and I'm not clear on why this isn't working. The code compiles and I am able to map to a sufficient CC value, however I can't transmit it to the middleware.
Any help is much appreciated. Thanks!
#include <MIDI.h>
#include <midi_Defs.h>
#include <midi_Message.h>
#include <midi_Namespace.h>
#include <midi_Settings.h>
struct MySettings : public midi::DefaultSettings
static const bool UseRunningStatus = false;
static const long BaudRate = 115200;
//declare custom MIDI instance. Formatted as (Serial Type (HW of SW), name of arduino serial, name of //port, custom settings)
MIDI_CREATE_CUSTOM_INSTANCE(HardwareSerial, Serial, MIDI, MySettings);
//declaring variable for previous MIDI value
int oldMIDIValue = 0;
//declaring variables for distance sensor
int trigPin = 10;
int echoPin = 13;
float duration, distance;
//Start listening for MIDI on the serial port. Used in place of Serial.begin()
MIDI.begin();
//setup for distance sensor
//Serial.begin(9600);
pinMode(trigPin, OUTPUT);
pinMode(echoPin, INPUT);
//Start the trigger at low
digitalWrite(trigPin, LOW);
delayMicroseconds(2);
//Send a trigger pulse
digitalWrite(trigPin, HIGH);
delayMicroseconds(10);
//go back to not sending a pulse
//define the duration
duration = pulseIn(echoPin, HIGH);
//calculate the distance between object and sensor based on response time
distance = (duration/2)*0.034;
//map the the distance between 0 and 127 (possible midi cc values)
oldMIDIValue = round(map(distance, 2, 400, 0, 127));
int newMIDIValue = round(map(distance, 2, 400, 0, 127));
if(newMIDIValue != oldMIDIValue){
//Send MIDI CC (Control Number (0-127), pot reading, MIDI Channel (1-16))
MIDI.sendControlChange(01, newMIDIValue, 1);
oldMIDIValue = newMIDIValue;
// if (distance >=400 || distance <= 2){
// Serial.println("out of range");
// }else{
// Serial.print("MIDI Value: ");
// Serial.println(newMIDIValue);
// //Serial.print("Distance: ");
// //Serial.println(distance);
I should add that I've used similar code(for the distance sensor)/same breadboard circuit for controlling a motor and so I'm confident that there's no physical mistake (declarations on wrong pins, etc.). I've also used the MIDI CC sends in a different program to interface with Hairless MIDI via pots in a different project. My sense is that maybe I can't send both MIDI out, and digital pulses to the sensor at the same time?
How likely is it that your if statement will ever succeed? You're comparing two values that have just been set up identically.
Steve
