Distance Sensor and MIDI Out
Hi
I am new to Arduino and have a few questions, so please bear with me.
I am wanting to use a distance sensor to output values through MIDI Out. This MIDI data will then control Ableton Live. The idea is that you stand away from the sensor and it plays a low note and as you move closer, it plays a higher note.
  1. Can anyone recommend a good sensor for this project?
I currently have a 10k Potentiometer that dims an LED using the following code:
  Analog input, analog output, serial output
 Reads an analog input pin, maps the result to a range from 0 to 255
 and uses the result to set the pulsewidth modulation (PWM) of an output pin.
 Also prints the results to the serial monitor.
 The circuit:
 * potentiometer connected to analog pin 0.
   Center pin of the potentiometer goes to the analog pin.
   side pins of the potentiometer go to +5V and ground
 * LED connected from digital pin 9 to ground
 created 29 Dec. 2008
 modified 30 Aug 2011
 by Tom Igoe
 This example code is in the public domain.
// These constants won't change.  They're used to give names
// to the pins used:
const int analogInPin = A0;  // Analog input pin that the potentiometer is attached to
const int analogOutPin = 9; // Analog output pin that the LED is attached to
int sensorValue = 0;        // value read from the pot
int outputValue = 0;        // value output to the PWM (analog out)
  // initialize serial communications at 9600 bps:
  // read the analog in value:
  sensorValue = analogRead(analogInPin);
  // map it to the range of the analog out:
  outputValue = map(sensorValue, 0, 1023, 0, 255);
  // change the analog out value:
  analogWrite(analogOutPin, outputValue);
  // print the results to the serial monitor:
  Serial.print("sensor = " );
  Serial.print(sensorValue);
  Serial.print("\t output = ");
  Serial.println(outputValue);
  // wait 10 milliseconds before the next loop
  // for the analog-to-digital converter to settle
  // after the last reading:
  delay(10);
  1. How would I go about changing the 10k Pot to a distance sensor?
  2. How would I change the output to be MIDI rather than an LED?
Try here Arduino Playground - InterfacingWithHardware
And here Arduino Playground - InterfacingWithHardware
People seem to have success with the Ping))) sensor: http://arduino.cc/en/Tutorial/Ping?from=Tutorial.UltrasoundSensor
Will that Ping Ultrasonic Range Finder work as a variable resistor? How would I get it to act like a 10K pot?
A pot, when read with analogRead(), gives you a number that relates to the position of the wiper. The ping sensor gives you a number that relates to the distance to an object in it's range. Once you have that number, where it came from isn't important.
