Distance sensor HELP
Hello, i am trying to make parking sensors for garage. And i dont know how to stop arduino code when car is not in garage or when it is parked. I need something like “if distance is same for 10 secs, stop code”
Here is my code:
#define trigPin1 9
#define echoPin1 8
#define Relay1 6
#define trigPin2 10
#define echoPin2 11
#define Relay2 7
long duration, distance, UltraSensor1, UltraSensor2; //we’ll use these variable to store and generate data
char data;
String SerialData="";
Serial.begin (9600);
pinMode(trigPin1, OUTPUT);
pinMode(echoPin1, INPUT);
pinMode(Relay1, OUTPUT);
pinMode(trigPin2, OUTPUT);
pinMode(echoPin2, INPUT);
pinMode(Relay2, OUTPUT);
SonarSensor(trigPin1, echoPin1);
UltraSensor1 = distance;
SonarSensor(trigPin2,echoPin2);
UltraSensor2 = distance;
while(Serial.available())
delay(10);
data=Serial.read();
SerialData+=data;
if(SerialData==“display distance”)
Serial.print(“distance measured by the first sensor: “);
Serial.print(UltraSensor1);
Serial.println(” cm”);
Serial.print(“distance measured by the second sensor: “);
Serial.print(UltraSensor2);
Serial.println("---------------------------------------------------------------------------------------------------------");
SerialData="";
if(UltraSensor1 <=15)
digitalWrite(Relay1,LOW);
digitalWrite(Relay1,HIGH);
if(UltraSensor2 <=15)
digitalWrite(Relay2,LOW);
digitalWrite(Relay2,HIGH);
if(UltraSensor1 <=5)//
delay(200);
delay(200);
if(UltraSensor2 <=5)
delay(200);
delay(200);
// SonarSensor function used to generate and read the ultrasonic wave
void SonarSensor(int trigPinSensor,int echoPinSensor)//it takes the trigPIN and the echoPIN
//START SonarSensor FUNCTION
//generate the ultrasonic wave
digitalWrite(trigPinSensor, LOW);// put trigpin LOW
delayMicroseconds(2);// wait 2 microseconds
digitalWrite(trigPinSensor, HIGH);// switch trigpin HIGH
delayMicroseconds(10); // wait 10 microseconds
digitalWrite(trigPinSensor, LOW);// turn it LOW again
//read the distance
duration = pulseIn(echoPinSensor, HIGH);
distance= (duration/2) / 29.1;
/----------------------- END PROGRAM -----------------------/
sketch_feb15b.ino (2.8 KB)
Add a boolean variable named timingInProgress to your code and set it to false. Each time you read the distance compare it with the last time you read it which you have previously saved. If the distance has not changed by a significant amount and timingInProgress is false then save the value of millis() as the period start time and set timingInProgress to true. If the distance has changed significantly then set timingInProgress to false
Further on in loop(), if timingInProgress is true and the current value of millis() minus the period start time is greater than 10 seconds then you know that the distance has not changed significantly during the timing period
void SonarSensor(int trigPinSensor,int echoPinSensor) Why a void function?
Why not have your function return the range for the given pins, instead of going via global variables?
You may find that reducing the ping rate to no more than about 20 - 30 Hz will produce more stable results.
Please remember to use code tags when posting code
Thank you for fast answer. I'm trying to understand what you told me but I can't because I'm new to Arduino. Could you write me an example that I can put in my code to try and redo something if need?
unsigned int SonarSensor(int trigPinSensor,int echoPinSensor)
  return (pulseIn(echoPinSensor, HIGH) / 2) / 29.1;
TheMemberFormerlyKnownAsAWOL:
I added this to my code and relays starts to turn on and turn off constantly.
But never mind distance is working fine on void. But I don’t know how to stop it when distance does not change? For example when I park car I want that relays to stop until car is moved again.
dzoni28:
We can’t see your code.
#define trigPin1 9
#define echoPin1 8
#define Relay1 6
#define trigPin2 10
#define echoPin2 11
#define Relay2 7
long duration, distance, UltraSensor1, UltraSensor2; //we'll use these variable to store and generate data
char data;
  delay(10);
  data=Serial.read();
  SerialData+=data;
if(SerialData=="display distance")
Serial.print("distance measured by the first sensor: ");
Serial.println(" cm");
Serial.print("distance measured by the second sensor: ");
SerialData="";
  delay(200);
  delay(200);
  delay(200);
  delay(200);
I can’t see where you call SonarSensor, and assign the return value to a variable.
Okay finally find code tags :smiley:
I understood you in theory but I don't know how to put it into practice (code}.
data=Serial.read();Here, you are assigning the value returned by the function “Serial.read” to the variable “data”.
Now, extend that same principle to the function “SonarSensor”.
Sorry, I don't understand you. I am giving up... I'm going to turn on and off it manually with switch. :frowning:
This timer example, Delay execution until condition has been true for X secs
from my How to Write Timers and Delays in Arduino tutorial is what you need
#include <millisDelay.h>
millisDelay executionDelay; // the delay object
unsigned long executionDelay_mS = 5000;
bool executedMethod = false;
bool condition() {  // returns when the condition is true
  return (Serial.read() == -1);  // Serial.read() returns -1 when there is nothing to read
  // other types of conditions could be  Range < 5cm etc
#define trigPin1 9
#define echoPin1 8
#define Relay1 6
#define trigPin2 10
#define echoPin2 11
#define Relay2 7
  // wait a few sec to let user open the monitor
  for (int i = 5; i > 0; i--) {
    Serial.print(i); Serial.print(' ');
  Serial.println("Enter input at least every 5 secs");
  if (executionDelay.justFinished()) { // nothing read for 10 sec
    //executionDelay only returns true once after start()
    // do something here
    executedMethod = true;  // only do this once even if condition remains true for a long time
    Serial.println(" No input for 5 sec.");
  if (condition()) {
    if (!executionDelay.isRunning() && (!executedMethod)) {
      // start it now
      executionDelay.start(executionDelay_mS);
    } // else already timing out don't disturb it OR has already timed out and executed
  } else { // condtion() is false  out side range etc
    // stop timer
    executionDelay.stop();
    // clear executedMethod so will execute again one condition is true for 5sec
  delay(200);
  delay(200);
  delay(200);
  delay(200);
I added it to my code, can you check this ?
Try this code
Only one sensor implemented and using Serial input to set near or far distance
millisDelay ledDelay1; // the delay object for led
unsigned long ledDelay1_mS = 3000;
#define trigPin1 9
#define echoPin1 8
#define Relay1 6
#define trigPin2 10
#define echoPin2 11
#define Relay2 7
bool sensor1Near = false;
  Serial.println("Enter n for near and f for far");
  // set  sensor1Near based on dist
  Serial.println("Currently sensor is far");
bool condition1() {  // returns when the condition is true
  char c = ' ';
  if (Serial.available()) {
    c = Serial.read();
  if (sensor1Near) {
    // looking for > 5
    if (c == 'f') { // for testing
      //  if (UltraSensor1 > 5) { // for real sensor
      Serial.println(F("Sensor is near"));
      return true;
    // looking for < 5
    if (c == 'n') { // for testing
      //if (UltraSensor1 < 5) { // for real sensor
      sensor1Near = true;
      Serial.println(F("Sensor is far"));
      return true;
  return false;
  if (ledDelay1.justFinished()) { // turn led off
    Serial.println(F("turn relay1 off"));
    digitalWrite(Relay1, LOW); // off
  if (condition1()) {
    ledDelay1.start(ledDelay1_mS);
    Serial.println(F("turn relay1 on"));
    digitalWrite(Relay1, HIGH); // on
void SonarSensor(int trigPinSensor, int echoPinSensor) {
  distance = (duration / 2) / 29.1;
drmpf:
Try this code
#define trigPin1 9
#define echoPin1 8
#define Relay1 6
#define trigPin2 10
#define echoPin2 11
#define Relay2 7
 for (int i = 5; i > 0; i–) {
   Serial.print(i); Serial.print(’ ');
 Serial.println(“Enter n for near and f for far”);
 Serial.println(“Currently sensor is far”);
 char c = ’ ';
   c = Serial.read();
 if (sensor1Near) {
   // looking for > 5
   if (c == ‘f’) { // for testing
     Serial.println(F(“Sensor is near”));
     return true;
   // looking for < 5
   if (c == ‘n’) { // for testing
     sensor1Near = true;
     Serial.println(F(“Sensor is far”));
     return true;
 return false;
   Serial.println(F(“turn relay1 off”));
if (condition1()) {
   Serial.println(F(“turn relay1 on”));
Finally someone understood that I am not a hacker and gave me finished code (I know to add other sensor It’s not problem) :smiley:
I tried the code, when I go into the serial monitor and type n for near and f for far. When I get out of the monitor nothing happens., and serial monitor is not showing current distance. Did I make a mistake somewhere?
Not sure what you mean here. The sample code does not actually read the UltraSensor but instead uses n and f to simulate the test for distance.
Check out the
  // looking for > 5[i][/i]
    if (c == 'f') { // for testing[i][/i]
section of the code. You need to replace the if (c == … with the line below
Ahh… well you need to add the print(UltraSensor1) statements back in.
