Distorted Image when saving to SD Card
Hi, good day folks. I have a problem regarding my on going project. I have an Arduino Mega2560, CC3000 Wifi Shield, an Arducam Mini wiht OV2640,a sensor. Now, heres what I’m trying to do. First, when a sensor detects something it would trigger the capturing of the image then it will do two possible options:
  1. Save to SD Card then send the image to a remote Server(PC) via the Wireless Network and save it to a MySQL database
    or
  2. It will directly save the image to the database of the Server.
Which one is more efficient to use?
and
While trying option number one, I have successfully captured and saved the image to the SD card attached to the Wifi Shield but I’m getting a distorted image like the one attached below.
#include <Adafruit_CC3000.h>
#include <ccspi.h>
#include <SPI.h>
#include <string.h>
#include "utility/debug.h"
#include "RTClib.h"
#include <SD.h>
#include <Wire.h>
#include <Thread.h>
#include <ArduCAM.h>
#include "memorysaver.h"
#define ADAFRUIT_CC3000_IRQ   3
#define ADAFRUIT_CC3000_VBAT  5
#define ADAFRUIT_CC3000_CS    10
Adafruit_CC3000 cc3000 = Adafruit_CC3000(ADAFRUIT_CC3000_CS, ADAFRUIT_CC3000_IRQ, ADAFRUIT_CC3000_VBAT,
                                         SPI_CLOCK_DIVIDER);
#define WLAN_SSID       ""
#define WLAN_PASS       ""
#define WLAN_SECURITY   WLAN_SEC_WPA2
#define IDLE_TIMEOUT_MS  3000
#define WEBSITE      "192.168.10.100"
#define WEBPAGE      ""
#define SD_CS 4
#define BMPIMAGEOFFSET 66
#define SPI_CS 53
const int pirPin = 48;
uint32_t ip = 3232238180;
const char bmp_header[BMPIMAGEOFFSET] PROGMEM =
      0x42, 0x4D, 0x36, 0x58, 0x02, 0x00, 0x00, 0x00, 0x00, 0x00, 0x42, 0x00, 0x00, 0x00, 0x28, 0x00,
      0x00, 0x00, 0x40, 0x01, 0x00, 0x00, 0xF0, 0x00, 0x00, 0x00, 0x01, 0x00, 0x10, 0x00, 0x03, 0x00,
      0x00, 0x00, 0x00, 0x58, 0x02, 0x00, 0xC4, 0x0E, 0x00, 0x00, 0xC4, 0x0E, 0x00, 0x00, 0x00, 0x00,
      0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xF8, 0x00, 0x00, 0xE0, 0x07, 0x00, 0x00, 0x1F, 0x00,
      0x00, 0x00
ArduCAM myCAM(OV2640,SPI_CS);
RTC_DS1307 rtc;
  uint8_t temp;
  uint8_t vid,pid;
  #if defined (__AVR__)
    Wire.begin();
  #endif
  #if defined(__arm__)
    Wire1.begin();
  #endif
  Serial.println("Program Start!\n");
  //Initialization of SD Card
  Serial.println(F("Initializing SD Card!"));
  if (!SD.begin(SD_CS)) {
    Serial.println(F("Initialization failed!\n"));
    while(1);
  Serial.println(F("Initialization done!\n"));
  //Initializing RTC
  Serial.println(F("Initializating RTC!"));
  if (!rtc.begin()){
    Serial.println(F("Failed to Initialize RTC!\n"));
  //rtc.adjust(DateTime(F(__DATE__), F(__TIME__)));
  Serial.println(F("Initialization of RTC sucessful!\n"));
  pinMode(SPI_CS, OUTPUT);
  pinMode(ADAFRUIT_CC3000_CS, OUTPUT);
  digitalWrite(SPI_CS, HIGH);
  digitalWrite(ADAFRUIT_CC3000_CS, LOW);
  SPI.begin();
  //ARDUCAM
  Serial.println("ArduCAM Start!");
  // set the SPI_CS as an output:
  //Check if the ArduCAM SPI bus is OK
  myCAM.write_reg(ARDUCHIP_TEST1, 0x55);
  temp = myCAM.read_reg(ARDUCHIP_TEST1);
  if(temp != 0x55)
    Serial.println("SPI interface Error!\n");
    while(1);
  myCAM.write_reg(ARDUCHIP_MODE, 0x00);
  //Check if the camera module type is OV2640
  myCAM.rdSensorReg8_8(OV2640_CHIPID_HIGH, &vid);
  myCAM.rdSensorReg8_8(OV2640_CHIPID_LOW, &pid);
  if((vid != 0x26) || (pid != 0x42))
    Serial.println("Can't find OV2640 module!\n");
    Serial.println("OV2640 detected\n");
  //Change to BMP capture mode and initialize the OV2640 module
  myCAM.set_format(BMP);
  myCAM.InitCAM();
  char str[8];
  unsigned long previous_time = 0;
  static int k = 0;
  uint8_t temp;
  myCAM.write_reg(ARDUCHIP_MODE, 0x01);      //Switch to CAM
  while(1)
    if(SENSOR-DETECTION)
         k = k + 1;
         itoa(k, str, 10);
         strcat(str,".bmp");        //Generate file name
         myCAM.write_reg(ARDUCHIP_MODE, 0x00);      //Switch to MCU, freeze the screen
         GrabImage(str);
void GrabImage(char* str)
  File outFile;
  char VH,VL;
  uint8_t temp;
  byte buf[256];
  static int k = 0;
  int i,j = 0;
  outFile = SD.open(str,O_WRITE | O_CREAT | O_TRUNC);
  if (! outFile)
    Serial.println("Open File Error");
    return;
  //Switch to FIFO Mode
  myCAM.write_reg(ARDUCHIP_TIM, MODE_MASK);
  //Flush the FIFO
  myCAM.flush_fifo();
  //Clear the capture done flag
  myCAM.clear_fifo_flag();
  //Start capture
  myCAM.start_capture();
  Serial.println("Start Capture");
  //Polling the capture done flag
  while(!(myCAM.read_reg(ARDUCHIP_TRIG) & CAP_DONE_MASK));
  Serial.println("Capture Done!");
  k = 0;
  //Write the BMP header
  for( i = 0; i < BMPIMAGEOFFSET; i++)
    char ch = pgm_read_byte(&bmp_header[i]);
    buf[k++] = ch;
  outFile.write(buf,k);
  k = 0;
  //Read 320x240x2 byte from FIFO
  //Save as RGB565 bmp format
  for(i = 0; i < 240; i++)
    for(j = 0; j < 320; j++)
      VH = myCAM.read_fifo();
      VL = myCAM.read_fifo();
      buf[k++] = VL;
      buf[k++] = VH;
      //Write image data to bufer if not full
      if(k >= 256)
        //Write 256 bytes image data to file from buffer
        outFile.write(buf,256);
        k = 0;
  //Close the file
  outFile.close();
  Serial.println("Done!");
  return;
Define what “more efficient” means to you. Neither approach will be fast or efficient.
Storing a link to a file in a database makes sense. Storing a file in the database does not.
There is nothing attached.
  while(1)
In a function that is already called in an endless loop. What a clueless thing to do.
Where is that defined?
    buf[k++] = ch;
Store the header in PROGMEM so that you can copy it to SRAM. The point of saving the data in PROGMEM escapes me.
I mean time efficient when constructing the code. And I cannot find something here in the forum that uses Wifi Shield as a device to send the image to the database. A quick link would be good.
I got some error while trying to attach the image.
i just placed SENSOR-DETECTION, but it must be a condition for a sensor
    buf[k++] = ch;
Im quite new to Arduino and such terms makes are hard for me to read.
PS: I just copied the code from the Arducam example and made some modifications on it
What is the attached png file? As far as I could see the Arducam does not return png files?
Mark
holmes4:
Mark
That's the saved file in the SD Card. just converted it to .png format becuase of some error uploading it here on the forums. it is on a .bmp format when saved
Make sure your BMP header is correct.
In your favorite image manipulation program, save a 320x240 image as an rgb565 BMP file.
See how much bigger than 153600 bytes the file is. The first (size - 153600) bytes is the header.
I tried this and got 2 variants (with and without color space information), neither is the same as yours.
With color space information, 138 bytes:
00000000  42 4d 8a 58 02 00 00 00  00 00 8a 00 00 00 7c 00  |BM.X..........|.|
00000010  00 00 40 01 00 00 f0 00  00 00 01 00 10 00 03 00  |..@.............|
00000020  00 00 00 58 02 00 13 0b  00 00 13 0b 00 00 00 00  |...X............|
00000030  00 00 00 00 00 00 00 f8  00 00 e0 07 00 00 1f 00  |................|
00000040  00 00 00 00 00 00 42 47  52 73 00 00 00 00 00 00  |......BGRs......|
00000050  00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
00000060  00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
00000070  00 00 00 00 00 00 00 00  00 00 02 00 00 00 00 00  |................|
00000080  00 00 00 00 00 00 00 00  00 00                    |..........|
and without color space information, 70 bytes:
00000000  42 4d 46 58 02 00 00 00  00 00 46 00 00 00 38 00  |BMFX......F...8.|
00000040  00 00 00 00 00 00                                 |......|
