Oh ok, sorry @Robin2 will not do.
Yeah @blh64 i ment that i understod that the Serial.print lines takes time, not the comment. just badly formulated from me.
And yes, dont really see what i intended with this line. it quite weird..
if (digitalPinToInterrupt(crankshaftReferencePin), CHANGE)
Went through the code again with a rubberduck, Notic i also connected one led-circuit wrong.
Got the reading side to work like intended with RISING like you said.
const byte IGTPin = 2; //Interrupt pin for IGT signal from ECU (pin3)
const byte crankPin = 3; //Interrupt pin for crankshaft reference pin (pin2)
volatile boolean syncAchieved = 0; //Set this to true if sync has been achieved
volatile byte cylinderCounter = 0; //Sequence which cylinder should fire (0-1-2-3)
const byte fireOrder[] = { //Table containing the fireorder (1-3-4-2)
B00000001, // cylinder 1-4
B00000010, // cylinder 2-3
B00000010 // cylinder 2-3
Serial.begin(19200); //for debug
pinMode(crankPin, INPUT_PULLUP); //Interrupt pin for crankshaft position Use pullup to get rid of dangerous wire break situation
pinMode(IGTPin, INPUT_PULLUP);
DDRB = 0b00000011; //Set the first 2 pins on the B register to outputs.
attachInterrupt(digitalPinToInterrupt(crankPin), ISR0, RISING);
Serial.println("Startup");
while (syncAchieved == 1) { //Start sequencing ignition outputs when sync has occured. Otherwise just wait until engine starts rotating.
PORTB = fireOrder[cylinderCounter];
void ISR0()
detachInterrupt(digitalPinToInterrupt(crankPin)); //If sync is achieved, we immedeatly disable keeping track of the position pin permanently
syncAchieved = 1; //Set variable used to start ignition and disable unnecessary measuring of position pin
Serial.println("Sync Achieved"); //Add when troubleshooting
attachInterrupt(digitalPinToInterrupt(IGTPin), ISR1, RISING); //We no longer keep track of change state once synced. Now we locate rising change on the ref pin.
void ISR1()
if (syncAchieved == 1) { //If we have achieved sync, do only this part of the interrupt
if (digitalRead(IGTPin) == HIGH) { //This is an "unneeded if". It filters out spark EMI, incorrect pulses will be counted otherwise.
cylinderCounter++; //we sequence the next cylinder that should fire
Serial.println(cylinderCounter); //debug line to see that the right cylinder are shooting
if (cylinderCounter > 3) {
cylinderCounter = 0; //This a reset for the cylinder firing sequencer. We have 4 cylinders, so we reset after we reached the final one.
For the detach line my intention is to use the syncing pin for the crank once to get it to fire in the right order, i dont think i need to check it again if the rest works correctly. But since a faulty spark can blow my engine up i might be good to check it every revolution?
Now the big question for me is the outputs, that i have set to port B?
I want them to send out a high signal. So when sync is achived i want cylinderCounter for 1 to be high, and after the IGT signal i want it to be low and cylinderCounter for 2 high.
How do i do that? since i got it to rotate correctly for the cylinder, the outputs dont become high.
The high signal of the output will go to a mosfet that awaits the IGT signal and then do the real switching between cylinders.
So from a risk analytic standpoint, do you guys se something in the code or am i missing something that would prevent blowing the engine?
All i have done is INPUT_PULLUP to get rid of a broken/loose connection from the sensors.
//Thanks
