DIY 16x8 transparent touchscreen from a simple glass
Hi there!
I am planning to create a 16x8 or smaller touchscreen and transparent screen display. Can you help me figure out how can I do this very cheap?
"Build"?
Whatever do you mean?
I built one back in 2020, here is a picture of it
The LEDs look brighter than that in real life, it is just they are hard to photograph.
It can be touch sensitive with a finger but you get the best results using a stylus, because you can be more accurate.
You need to start with a glass touch screen, you can't make that yourself because it involves using vacuum deposition of metals onto glass. This was a resistive touch screen not the capacitive type.
Then I fitted two 8X8 WS2812 panels under it and some 0.5mm sheet polystyrene to act as a diffuser.
This was a project for the Raspberry Pi but the hardware could easily be driven with an Arduino.
It was published in the MagPi magazine in three parts in numbers 97, 98 and 99. You can download free PDF of the magazine from
https://magpi.raspberrypi.com/issues/97
And the same link but ending /98 and /99 for the other issues.
Videos at
https://www.youtube.com/watch?v=Q7rMKh6I7Lo
https://www.youtube.com/watch?v=Cc29lIrQY8I&t=1s
https://www.youtube.com/watch?v=f_-N9cFt4uI
I am very sorry for my english.
Thank you very much for the suggestions!
