DIY Camera
Hi I'am new to Programming for Arduino. I found a project on instructables.com can anyone help me put with it whenever I load it it says either there is too much in one typee of ram or the other I downloaded everything I could find on GitHub and intractables and googled the rest. I have attached all of the files here. I tried loading this on a std Arduino and a yun but neither worked I ordered a mega hoping that may fix it but am looking for some guidance on memory management for this and future projects. I would love to be able to get this working on a std Arduino as many schools in the area have placed ideas for such a device for various science project nature stations etc etc.
thanks for any help you can provide. Not I have attached the instructables pdf as well since the directions are incomplete now as they do not work to see if they can be updated for use.
Chris Zolinski
Webmaster
Montrose eagles 4090
http://www.montroseeagles.com/?path=arduino.zip%3F
Arduino-Ethernet-Camera.pdf (243 KB)
Not too many of us are interested in downloading zip files that people attach.
You need to post the code, between code tags, then independently attach any schematics etc that might be relevant.
If you read these posts, they will give you more information on how to post and how to use code tags:-
How to use this forum - please read
A link to the relevant "Instructable" might help, too.
I like the conversion of Instructables to intractable, it sums up the crap quality of that site nicely.
OldSteve:
There are more than one reason for that! :astonished:
#include <Adafruit_VC0706.h>
#include <SPI.h>
#include <SdFat.h>
#include <SdFatUtil.h>
#include <Ethernet.h>
#include <SoftwareSerial.h>
// Arduino Ethernet shield: pin 4
#define chipSelect 4
// Using SoftwareSerial (Arduino 1.0+) or NewSoftSerial (Arduino 0023 & prior):
#if ARDUINO >= 100
// On Uno: camera TX connected to pin 2, camera RX to pin 3:
SoftwareSerial cameraconnection = SoftwareSerial(2, 3);
// On Mega: camera TX connected to pin 69 (A15), camera RX to pin 3:
//SoftwareSerial cameraconnection = SoftwareSerial(69, 3);
#else
NewSoftSerial cameraconnection = NewSoftSerial(2, 3);
#endif
Adafruit_VC0706 cam = Adafruit_VC0706(&cameraconnection);
/************ ETHERNET STUFF ************/
byte mac[] = {0x90, 0xa2, 0xda, 0x0e, 0xf7, 0xfc};
byte ip[] = {192, 168, 0, 30};
char rootFileName[] = "index.htm";
EthernetServer server(80);
/************ SDCARD STUFF ************/
SdFat SD;
Sd2Card card;
SdVolume volume;
SdFile root;
SdFile file;
// store error strings in flash to save RAM
#define error(s) error_P(PSTR(s))
void error_P(const char* str) {
PgmPrint("error: ");
SerialPrintln_P(str);
if (card.errorCode()) {
PgmPrint("SD error: ");
Serial.print(card.errorCode(), HEX);
Serial.print(',');
Serial.println(card.errorData(), HEX);
while (1);
/*SETUP()/
#if !defined(SOFTWARE_SPI)
#if defined(AVR_ATmega1280) || defined(AVR_ATmega2560)
if (chipSelect != 53) pinMode(53, OUTPUT); // SS on Mega
#else
if (chipSelect != 10) pinMode(10, OUTPUT); // SS on Uno, etc.
#endif
#endif
PgmPrint("Free RAM: ");
Serial.println(FreeRam());
digitalWrite(10, HIGH);
if (!card.init(SPI_HALF_SPEED, 4)) error("card.init failed!");
if (!volume.init(&card)) error("vol.init failed!");
PgmPrint("Volume is FAT");
Serial.println(volume.fatType(), DEC);
if (!root.openRoot(&volume)) error("openRoot failed");
PgmPrintln("Files found in root:");
root.ls(LS_DATE | LS_SIZE);
PgmPrintln("Files found in all dirs:");
root.ls(LS_R);
PgmPrintln("Done");
Serial.println("VC0706 Camera snapshot test");
if (!SD.begin(chipSelect)) {
Serial.println("Card failed, or not present");
return;
Ethernet.begin(mac, ip);
server.begin();
#define BUFSIZ 100
/*LOOP()/
char clientline[BUFSIZ];
char *filename;
int index = 0;
int image = 0;
if (client) {
boolean current_line_is_blank = true;
index = 0;
while (client.connected()) {
if (client.available()) {
char c = client.read();
if (c != '\n' && c != '\r') {
clientline[index] = c;
index++;
if (index >= BUFSIZ)
index = BUFSIZ - 1;
continue;
clientline[index] = 0;
filename = 0;
Serial.println(clientline);
if (strstr(clientline, "GET / ") != 0) {
filename = rootFileName;
if (strstr(clientline, "GET /") != 0) {
if (!filename) filename = clientline + 5;
(strstr(clientline, " HTTP"))[0] = 0;
Serial.println(filename);
if (strstr(filename, "tttt") != 0)
takingPicture();
if (strstr(filename, "rrrr") != 0)
removePicture();
if (! file.open(filename, O_READ)) {
client.println("HTTP/1.1 404 Not Found");
client.println("Content-Type: text/html");
client.println();
client.println("
File Not Found!
Serial.println("Open!");
if (strstr(filename, ".css") != 0)
client.println("Content-Type: text/css");
else if (strstr(filename, ".htm") != 0)
else if (strstr(filename, ".jpg") != 0)
client.println("Content-Type: image/jpeg");
client.println();
int16_t c;
while ((c = file.read()) >= 0) {
Serial.print((char)c);
client.print((char)c);
file.close();
// everything else is a 404
client.println();
client.println("
File Not Found!
client.stop();
/*FUNCTION1()/
void takingPicture() {
if (cam.begin()) {
Serial.println("Camera Found:");
Serial.println("No camera found?");
return;
char *reply = cam.getVersion();
if (reply == 0) {
Serial.print("Failed to get version");
Serial.println("-----------------");
Serial.print(reply);
//cam.setImageSize(VC0706_640x480); // biggest
cam.setImageSize(VC0706_320x240); // medium
//cam.setImageSize(VC0706_160x120); // small
uint8_t imgsize = cam.getImageSize();
Serial.print("Image size: ");
if (imgsize == VC0706_640x480) Serial.println("640x480");
if (imgsize == VC0706_320x240) Serial.println("320x240");
if (imgsize == VC0706_160x120) Serial.println("160x120");
Serial.println("Snap in 3 secs...");
delay(3000);
cam.takePicture();
Serial.println("taking picture");
file.open("IMAGE.jpg", O_RDWR | O_CREAT);
uint16_t jpglen = cam.frameLength();
pinMode(8, OUTPUT);
byte wCount = 0;
while (jpglen > 0) {
uint8_t *buffer;
uint8_t bytesToRead = min(32, jpglen);
buffer = cam.readPicture(bytesToRead);
file.write(buffer, bytesToRead);
if (++wCount >= 64) {
Serial.print('.');
wCount = 0;
jpglen -= bytesToRead;
file.close();
Serial.println("end of taking picture");
/*FUNCTION2()/
void removePicture() {
file.open("IMAGE.jpg", O_READ | O_WRITE);
file.remove();
Right, first things first.
Go and read the instructions, then go back and modify your post (use the "More --> Modify" option to the bottom right of the post) to mark up the code as such so we can review it conveniently and accurately.
Note: Also mark up any data in the same way. This includes error output that you get from the IDE.
@czolinski, I see that you still didn't bother to read the posts that I linked to, or even properly read mine, since you didn't enclose your code in code tags.
Why do I feel like I wasted my time?
Thanks, Paul. I see that you've already pointed it out, but I'll post this anyway, to help drive the point home.
Grumpy_Mike:
Ha, yeah, I picked up on that too. Wondered if it was intentional.
OldSteve:
You are most welcome. :grinning:
I look at it this way. I figure if you can't figure out the instructions (on how to mark up your code), then any other advice is pretty useless. This business of computer coding (which "they" say they are going to start teaching in schools :roll_eyes: ) is all about detail.
Paul__B:
....which "they" say they are going to start teaching in schools :roll_eyes: )
Wouldn't it be nice if they did. Then people might actually learn the basics before taking on megalithic projects.
(I won't hold my breath though.)
We can but hope.
I think the main problem is SiFi leading people to thinking there is a highly accurate sensor for everything you could think of.
Grumpy_Mike:
We can but hope.
Do you mean there isn't? :smiley:
@czolinski, sorry for getting off-track. We'll be good now. :wink:
And we'll help with your code when you help by placing it within code tags. Fair deal?
I'm able to successfully compiled your code using IDE 1.0.6 on UNO and with this SdFat libraries
http://sdfatlib.googlecode.com/files/sdfatlib20130629.zip
