DIY CNC gripper Problem (HELP)
Hi i am new in arduino and G-code
I am planning to do a project which is CNC 2 axis movement machine with gripper by using G code
i am using:
  1. Arduino Uno
  2. Adafruit Motor Shield L293D V1
(http://www.lazada.com.my/motor-drive-expansion-shield-module-l293d-for-arduino-duemilanovemega-uno-8458754.html?ff=1)
3)Universal G-code Sender
I had flash GRBL into my arduino. Here is the few questions
1)Can G-code function with this Adafruit Motor Shield L293D V1?
2)Can G-code control also servo motor? Because in this project i am planning to use 2 stepper motor to move the machine in X and Y direction.While Servo Motor is planning to use at the gripper in order to gripper the workpiece.If can,How? If cant, then how should i able to function my servo motor?
Hope all Pro can help me
Thanksss
Apparently you did not read/study Home · grbl/grbl Wiki · GitHub before deciding what you wanted to do.
Paul
