Backstory - I’ve been building a ground up CNC Mill of my own design. It’s working wonderfully and of course I keep making upgrades and changes.
One such upgrade is a gauge assembly that’s using a uno, voltage dividers and a SSD1306 display. I’m calculating spindle rpm from the spindle control voltage at it’s max speed. The voltage through the 12v (1m/100k voltage divider, 55v max) power supply for the mill seems to be reading pretty accurately vs a multimeter. The voltage though the spindle controller varies with a pot from 5-100v (1m/20k voltage divider, 255v max, read some 170ish with a multimeter) reads all over the place. I’ve tried filtering however it’s still erratic. I believe I’m getting interference from the spindle itself. I’ve posted my code below to browse over. Would a low pass filter help or code filter of some sort that I’m missing. I did remove the code filter I had only because it wasn’t really working.
#include <SPI.h>
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#define SCREEN_WIDTH 128
#define SCREEN_HEIGHT 32
#define OLED_RESET 4
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET);
//MILL VOLTAGE MEASUREMENT VARIABLES
unsigned int voltageraw;
float voltageadc;
float voltage = 0.0;
//SPIN VOLTAGE MEASUREMENT VARIABLES
unsigned int voltagerawS;
float voltageadcS;
float voltageS = 0.0;
//SPINDLE RPM MEASUREMENT VARIABLES
float RPM;
float spinmaxvolt = 100; //CHECK WITH MULTIMETER
float spinmaxrpm = 12000; //CHECK WITH LASER TACH
float voltperrpm;
//SPINDLE TEMPERATURE MEASUREMENT VARIABLES
int Vo;
float R1 = 10000;
float logR2, R2, T;
float c1 = 1.009249522e-03, c2 = 2.378405444e-04, c3 = 2.019202697e-07;
float T1;
float T2;
float T3;
void setup(void) {
if (!display.begin(SSD1306_SWITCHCAPVCC, 0x3C)) {
Serial.println(F("SSD1306 allocation failed"));
for (;;);
display.display();
display.clearDisplay();
display.setTextSize(2);
display.setTextColor(SSD1306_WHITE);
display.setCursor(20, 0);
display.println(F("HCM2011"));
display.setCursor(13, 18);
display.println(F("CNC MILL"));
display.display();
delay(2750);
MILLVOLT();
SPINVOLT ();
TACHRPM();
SPINTEMP();
void MILLVOLT() {
voltageraw = analogRead(A3);
voltageadc = voltageraw * 0.0048828125; //5.000/1024
voltage = voltageadc * 11.00; //* 55 MAX VOLT/5 VOLT
display.setCursor(0, 0);
display.println(F("MILL VOLT"));
display.setCursor(0, 18);
display.println(voltage);
display.display();
delay(2750);
void SPINVOLT() {
voltagerawS = analogRead(A1);
voltageadcS = voltagerawS * 0.0048828125; //5.00/1024
voltageS = voltageadcS * 51.000; // 255 MAX VOLT/5 VOLT
display.println(F("SPIN VOLT"));
display.println(voltageS);
display.display();
delay(2750);
void TACHRPM() { //NOT EXTREMELY PRECISE LINEAR PROJECTION OF VOLTAGE AT MAX RPM
voltperrpm = spinmaxrpm / spinmaxvolt;
RPM = voltageS * voltperrpm; //MOTOR VOLTAGE AT 12000 RPM IS 100V
display.println(F("SPIN RPM"));
display.println(RPM);
display.display();
delay(2750);
void SPINTEMP() {
Vo = analogRead(A2);
R2 = R1 * (1023.0 / (float)Vo - 1.0);
logR2 = log(R2);
T1 = (1.0 / (c1 + c2 * logR2 + c3 * logR2 * logR2 * logR2));
T2 = T1 - 273.15;
T3 = ((T2 * 1.800) + 32.0) * .95; //0.95 CORRECTION VALUE
display.print(F("SPIN F"));
display.println(T3);
display.display();
delay(2750);
