Hello Arduino community,
I am looking to create a DIY solution for controlling the pan and tilt of my Chauvet LED Followspot 75sT using Arduino and stepper motors. Specifically, I want to be able to remotely control the pan and tilt movements of the Followspot using a DMX light controller software like LightKey.
Here's some information about the Followspot:
- Weight: 15 pounds
- Mounting: M12 bolt
After researching different options, I have decided to use stepper motors as they provide precise position control and can handle heavier loads than most servo motors. I plan to mount the stepper motors onto a bracket that can accommodate an M12 bolt, and use a linkage system to connect the motors to the pan and tilt mechanisms of the Followspot.
To control the stepper motors, I plan to use an Arduino board, along with two stepper motor drivers, a breadboard, and jumper wires. I will write a simple program using the "AccelStepper" library to control the motors, and connect the Arduino board to a DMX interface that can translate DMX signals into serial data that can be read by the Arduino. I plan to use a DMX light controller software like LightKey to send DMX signals to the interface, which will control the pan and tilt of the Followspot based on the signals it receives.
I have a few specific questions about this project:
- What is the optimal torque and speed rating for the stepper motors I should use to handle the 15-pound weight of the Followspot?
- What DMX interface do you recommend using with Arduino for this application?
- How will I build the mount for the Followspot and ensure it’s securely mounted to the stepper motors and linkage system?
- Can anyone help me with the coding, complete beginner
Thank you in advance for your guidance and advice!
Some nice references I like to go off of:
