I'm new to the business of making PCB's and am having mixed results from my efforts. I'll describe what I'm doing before getting into the problems. I use the free version of eagle CAD (conveniently its size limits just allow a mega shaped board). I design my boards with 0.254 inch track and 0.254 spacing. I print the designs on a Samsung ML-2525W printer onto LaserStar translucent film (http://www.megauk.com/artwork_films.php), then I expose to UV using a commercial light box (http://www.megauk.com/uv_exposure_units.php) before developing for about 30 seconds and then etching in ferric chloride.
When I first started doing this my printer was new and everything seemed to be working fine, after dozens of successful boards , something started to go wrong, after examining the boards under a 20x microscope I noticed that many of my tracks were 'over etched' and in some cases etched right through. I tried reducing the etch time, but this just left a lot of the board incomplete. After a lot of head scratching I compared some of my early artwork (from successful boards) to my latest artwork (from unsuccessful boards) and discovered that the printer had started laying down quite thin layers of toner, which was probably leading to poor development of the board, and hence to poor etching.
I bought a new cartridge for the printer, but the error remained. I then tried a genuine Samsung toner cartridge (thinking the 1st might have been a cheap Chinese knock-off) but still no improvement.
Any suggestions? Is my guess that the thinness of the toner layer is the root of the problem likely to be correct? Or could there be another problem ? The chemicals and acetates haven't changed, the only difference I'm aware of is the toner cartridge, I've tried running the acetate through the printer multiple times to build up a thicker layer of toner, but it's impossible to get the two layers to align, I've tried using two copies of the same artwork (on two sheets), but again its almost impossible to get them to match up.
The only other solution I can think of is to start using much thicker tracks with greater clearance but this would force me to use larger designs and larger boards.
