DIY plastic Box for projects.
I sometimes make small plastic boxes for Arduino projects.
I use a solvent to weld the side walls to the top.
The solvents viscosity is similar to Acetone.
I have used:
  • a syringe to deliver the solvent to the inside corners, but find it applies too much solvent.
  • a squeeze bottle with a fine needle but this too applies to much solvent.
  • a small bladed screw driver dipped in the solvent to remove a drop at a time, this seems to be the best method out of the three.
Are there any other suggestions you might offer to apply a very small controlled amount of solvent?
I would try PVC pipe cement from the hardware store. It is essentially thick acetone and it has a fuzzy applicator built into the cap.
In the past ive used MEK and a syringe, but found it can squirt out fast
maybe use a q-tip and apply to the surfaces before putting together?
There is also plasti-zap.....
For some strange reason you have not told us what solvent you are actually using.
The solvent used to join polystyrene can be applied with a small paint brush. If the brush goes hard after use it softens again when it is next used.
...R
Oops.
Brand name is: "Fast Bond" (methylene chloride).
Plastics are acrylic.
Usually one drop is needed for each 4 to 5 cm.
Edit:
I have thicken the "Fast Bond" by dissolving acrylic pieces in it, good for any voids.
A process similar to this but, I am trying to not use the applicator shown as too much solvent is delivered:
I found this, looks promising:
Also:
How to use:
I just tried the first tool above.
I made one out of two needles side by side and kept in place by crimping them in a small diameter brass tube. Cost ~ 5 cents :wink:
Here's what I would use - if money was no object (depending on how often you build such cases, and whether you sell them - this set of tools might be cheap):
Repeating Dispenser - 50 uL (1 drop)
Syringe (1000 series - 2.5 mL - 50 drops)
Needles (15 gauge KelF Hub x6)
As you can see, that kit will set you back about $200.00 USD - but maybe now, knowing what these items are called, you can find something that does the same job, but cheaper?
Another option - a peristaltic pump, like this one:
Remove the DC motor, and replace it with a stepper, then build a dispenser with a syringe and a button, set up a controller using an Arduino and LCD - and then you should be able to measure out precise amounts on a drop by drop basic per button press.
@cr0sh
I like the Repeating Dispenser - 50 uL (1 drop) very much.
If I did a lot of this stuff I would get one.
I use the more viscous "medium bodied" acrylic cement. I paint it on the surfaces I want to bond. It's mainly for filling in imperfections in surfaces that don't mate perfectly.
jboyton:
Yes, if there are voids to deal with.
Version two using 2 needle method:
NOT for glues which are thick but for "fast Bond" methylene chloride, this works GREAT!
Fountain pen?
Capillary tube?
This...
https://www.google.com/search?q=machine+oil+dispenser
Led me here...
http://www.gauntindustries.com/1_2_Ounce_Clear_Bottle-HYPO-2005.html
Ruling pen? . . . . adjustable, cleanable, rounded tip.
@Coding Badley @Archibald
  • Oil pen looks interesting!
  • I like your idea of using the pen.
    Brings back memories of old school days.
    Hey, maybe a feather quill LOL.
I will look for something like those.
Fast Bond boils at 40 degrees Celsius so will have to get an enclosed reservoir.
