DIY ribbon touch sensor
So I'm working on a project that will utilize ribbon sensors to create a whole bunch of "touch bars". I need them long (~50cm), and I need plenty of them (4-6) next to each other in a narrow space (~45mm), so this kind of stuff form Adafruit won't work, and the cost of longer off-the-shelf devices I've seen around the 'net would blow my budget. (They also seem to be hard to get in EU, and I'd rather avoid overseas shipping.)
This guy did a cool DIY ribbon sensor using video tape as the resistive material:
https://web.archive.org/web/20180131161410/http://memoir.okno.be/phys_comp_tutorial/ribbon4/ribbon4.htm
So I bought some recordable audio tape - can't really tell what is it made of, specs are very scarce, but it's a "Maxell UR". And it doesn't seem to conduct any electricity at all, let alone act as a linear potentiometer. I've checked both sides, with a multimeter, with a battery and a motor, etc, it's just dead like a dead parrot.
I suspect it's either coated with some extra layer, or is using some other technology for the magnetic layer (sadly I couldn't find the text of the IEC 60094 standard that deals with these tapes that wasn't protected by a pay-wall).
What would be my options? I don't even know which kind of tape I should be hunting for, and it was already pretty difficult to find any at all. Should I use video tape instead? Again, which kind?
Any pointers would be greatly appreciated.
I know it's been over a year, but I am working on a Very simerler project and would like to know if you ever got your's working.
I've found that VCR tape is conductive with mine being around 20Mohms per meter but I've found my signal is incredibly noisy.
