i see.
is possible #define what incluse, so we can leave out LCD and camera, and just use a pc to display data?
lesto:
i see.
Thats the idead behind V1 You can always build it on your own, here you go: http://www.cheap-thermocam.net/downloads-v1/
Update: The successor of the Cheap-Thermocam V4, called DIY-Thermocam, is now available as a self-assembly kit ! For more information, check out www.diy-thermocam.net
Update 2: Today, the store has been updated!
It's now also possible to buy single components, either from me or an external distributor near you. That enables you to choose what parts you want to buy, and from what source.
In addition, I added the schematic and the enclosure design file to the download section. So if you want to make your own nice case or your own board, you can do that easily !
Check out the new store concept: http://www.diy-thermocam.net/store/
There have been some changes, which I would like to inform you about:
- A new thermal analysis software for the PC is available, called ThermoVision. It allows various options to edit, analyze and save thermal data from the device.
- The standalone thermal viewer software written in Python allows HQ thermal live streams, taking photos & recording videos on the PC. As always, the source code is open-source.
- The USB serial communication protocol is now open, so everyone can communicate with the DIY-Thermocam easily and write own applications or get access to the raw data.
Check out www.diy-thermocam.net for all the new updates!
I am happy to announce, that the DIY-Thermocam V2 is here! It contains a lot of improvements towards the previous generation, based on the feedback of all customers and the experience from the last two years.
The project has moved to Github.
You can now make your own DIY-Thermocam V2 by purchasing the components on the list on your own. Everything is open-source, including the gerber files for the PCB, the protocol, the firmware itself (written in Arduino compatible code!).
Hope you like it and I would be happy to receive your feedback
lestofante:
i see.
Hi, I also want to display in a pc, have you tried?
leyuanma:
Pipe the data to Processing?
(You do realise this thread is nearly four years old?)
