In case you cannot see the code with the link, here's the code:
//Code: VaccumCode
//Version: 2.0.1
//Author: Cesar Nieto refer to ces.nietor@gmail.com
//Last change: 19/05/2017
//Changes: Documentation added
#include <math.h>
////////////PINS////////////////
//Distance Analog Sensors (Sharp)
const int SD1 = 0; //left front sensor
const int SD2 = 1; //right front sensor
const int SD3 = 2; //left side sensor
const int SD4 = 3; //right side sensor
//Battery Voltage input
const int battery = 4;
//IndicatorLED
const int led = 13;
//Fan output
const int fanmotor = 12; // the number of the LED pin
// Motor1 Right
const int motor1Pin1 = 3;
const int motor1Pin2 = 5;
// Motor2 Left
const int motor2Pin1 = 6;
const int motor2Pin2 = 9;
//Bumper
const int bumper1 = 10;
const int bumper2 = 11;
const int bumper3 = 7;
const int bumper4 = 8;
///////////////Constants////////////////
const float voltageBatCharged = 12.68; // Voltage measured when battery fully charged //Change this
//PWM for the micro metal motors
const int pwmMax = 160;// for 12V pwmMAx = 170, for 10V output pwmMax = 140
const int pwmMin = 70;;// for 9V pwmMin = 128
//Mínimun distance of the sensor
const int minSharp = 30;
// Variables will change:
int bumperState = 0; // variable for reading the pushbutton status
boolean control = true;
int counter = 0; // Prevents from being stuck
int bumperState2 = 0; // variable for reading the pushbutton status
boolean control2 = true;
int counter2 = 0; // Prevents from being stuck
int bumperState3 = 0; // variable for reading the pushbutton status
boolean control3 = true;
int counter3 = 0; // Prevents from being stuck
int bumperState4 = 0; // variable for reading the pushbutton status
boolean control4 = true;
int counter4 = 0; // Prevents from being stuck
//////////////CODE/////////////
//Initialize outputs and inputs
//Fan motor as output
pinMode(fanmotor, OUTPUT);
//Motor1
pinMode(motor1Pin1, OUTPUT);
pinMode(motor1Pin2, OUTPUT);
//Motor2
pinMode(motor2Pin1, OUTPUT);
pinMode(motor2Pin2, OUTPUT);
//LED
pinMode(led, OUTPUT);
//INPUTS
// initialize the pushbutton inputs
//Bumper
pinMode(bumper1, INPUT_PULLUP);
pinMode(bumper2, INPUT_PULLUP);
pinMode(bumper3, INPUT_PULLUP);
pinMode(bumper4, INPUT_PULLUP);
//Sensor
pinMode(SD1, INPUT);
pinMode(SD2, INPUT);
pinMode(SD3, INPUT);
pinMode(SD4, INPUT);
//Batt
pinMode(battery, INPUT);
// Initialize serial
///////////////////////////////Wait////////////////////////////////////////
//Wait about 5 s and initialize fan if voltage ok
waitBlinking(5,1); //5 seconds at 1 Hz
//Crank (initialize the fan because the voltage drops when cranking)
if(readBattery(battery)>12.1){
digitalWrite(fanmotor, HIGH); //Turn the Fan ON
delay(1000); //For 1000ms
else {
//do nothing Convention
//////////Functions To Use //////////
void waitBlinking(int n, int frequency){
//blink for n seconds at frequency hz
for (int i=1; i <= n; i++){
for(int j=1; j<=frequency; j++){
digitalWrite(led, HIGH);
delay((1000/frequency)/2); //Half time on
digitalWrite(led, LOW);
delay((1000/frequency)/2); //Half time off
double sdSHARP(int Sensor){
//Returns the distance in cm
double dist = pow(analogRead(Sensor), -0.857); // x to power of y
return (dist * 1167.9);
void forwardMotors(int moveTime){
//Manipulate direction according the desired movement of the motors
analogWrite(motor1Pin1, pwmMin);
analogWrite(motor1Pin2, 0); //PWM value wher 0 = 0% and 255 = 100%
analogWrite(motor2Pin1, pwmMin);
analogWrite(motor2Pin2, 0);
delay(moveTime);
void rightMotors(int moveTime){
analogWrite(motor1Pin1, 0);
analogWrite(motor1Pin2, pwmMin);
delay(moveTime);
void leftMotors(int moveTime){
analogWrite(motor2Pin1, 0);
analogWrite(motor2Pin2, pwmMin+20);
delay(moveTime);
void backwardMotors(int moveTime){
analogWrite(motor1Pin2, pwmMin+20);
delay(moveTime);
void stopMotors(){
float readBattery(int input){
int readInput;
float voltage;
readInput = analogRead(input);
voltage = (((readInput*4.9)/1000)*voltageBatCharged ) / 5; // resolution of analog input = 4.9mV per Voltage
Serial.print(" Battery= ");
Serial.print(voltage);
return voltage;
void batteryControl(int input){
//Turn everything off in case the battery is low
float v_battery;
v_battery = readBattery(input);
if(v_battery<=11.6){ //battery limit of discharge, Don't put this limit lower than 11.1V or you can kill the battery
control = false;
else {
//Do nothing Convention
/////////////////////////////////////////////////MAIN CODE//////////////////////////////
void loop(){
Serial.print("SD1= ");
Serial.print(sdSHARP(SD1));
Serial.print(" SD2= ");
Serial.print(sdSHARP(SD2));
delay(200);*/
bumperState = digitalRead(bumper1);
bumperState2 = digitalRead(bumper2);
bumperState3 = digitalRead(bumper3);
bumperState4 = digitalRead(bumper4);
//Keep the control of the battery automatically turn the fan off
//If control = true the battery level is ok, otherwise the battery is low.
batteryControl(battery); //modifies the variable control of the battery is low
if (control){
while (!sdSHARP(SD1)<=4.3 && !sdSHARP(SD2)<=4.3 && !bumperState==0 && !bumperState2==0 && !bumperState3==0 && !bumperState4==0); {
forwardMotors(5100);
backwardMotors(300);
leftMotors(300);
forwardMotors (4800);
backwardMotors(400);
rightMotors(350);
forwardMotors(5000);
backwardMotors(280);
rightMotors(320);
forwardMotors (5200);
backwardMotors(410);
rightMotors(350);
forwardMotors(4500);
backwardMotors(310);
leftMotors(320);
rightMotors(350);
forwardMotors (300);
if (sdSHARP(SD1)<=4.3 ){
//If the distance between an object and the left front sensor is less than 4.3 cm or the bumper hits, it will move to the left
if (counter ==2){ // prevent of being stuck on corners
counter = 0;
else {
forwardMotors(100); // approach a bit
backwardMotors(500); // backward delay of 500ms
leftMotors(300);
counter = counter + 2;
Serial.print(" Turn Left ");
else if (sdSHARP(SD2)<=4.3){
//If the distance between an object and the right front sensor is less than 4.3 cm, it will move to the right
if (counter ==1){
counter = 0;
else{
forwardMotors(100);
rightMotors(300);
counter++;
Serial.print(" Turn Right");
else if (bumperState==0){//BUMPER1
counter = 0;
backwardMotors(1500); //backward delay of 500ms
leftMotors(500);
else if (bumperState2==0){//BUMPER2
counter2 = 0;
rightMotors(400);
Serial.print(" Turn Right ");
else if (bumperState3==0){//BUMPER3
counter3 = 0;
leftMotors(500);
else if (bumperState4==0){//BUMPER4
counter = 4;
rightMotors(400);
else {
if(counter==3){ //Corner
leftMotors(1000);
counter = 0;
else {
forwardMotors(0);
Serial.print(" Move Forward");
else if (!control){
//If the battery is low, turn everything off
digitalWrite(fanmotor, LOW); //Turn the Fan OFF
stopMotors();
Serial.print(" Low Battery! ");
waitBlinking(1,3); //blink as warning 3hz in a loop
