Hi
Im using this motor shield to control 2 dc motors (for wheels)
I wired them up and tested them using this code which worked as expected.
#include <AFMotor.h>
AF_DCMotor RHS(1);
AF_DCMotor LHS(2);
int spd=0;
void go(){
RHS.setSpeed(spd);
LHS.setSpeed(spd);
RHS.run(FORWARD);
LHS.run(FORWARD);
while(spd<=255){
Serial.println(spd);
go();
RHS.run(RELEASE);
LHS.run(RELEASE);
delay(250);
spd++;
spd=0;
I then wrote the code for the vehicle and put in a go() routine that starts the motors.
i used the go() routime in the setup() to test motor rotation. this worked as expected.
Hower any subsequent calls to the go() routine do not start the motors. Theres a serialprintln in the routine which shows that its called.
so the motor.run commands seem to work first time they are called only. I cant for the life of me see why the test sketch worked and the final one doesn't
anyone?
#include "Ultrasonic.h";
#include "Servo.h";
#include "AFMotor.h";
//define motors and servo
AF_DCMotor RHS(1);
AF_DCMotor LHS(3);
Servo head;
Ultrasonic ultrasonic(2,8);
// Define variables
int spd=65;
int RUNNING=false;
int turntime=500;
int cycles=0;
//distance toobject limits
const int Dlimit=30;
const int Slimit=15;
int Dist=0;
int LDiag=0;
int LDist=0;
int RDiag=0;
int RDist=0;
int Avg[3];
int Direction=0;
void setup(){
head.attach(9);
head.write(75);
pinMode(2,OUTPUT);
pinMode(A0,OUTPUT);
pinMode(8,INPUT);
RHS.setSpeed(spd);
LHS.setSpeed(spd);
go();
delay(5000);
allstop();
digitalWrite(A0,HIGH); delay(5000);digitalWrite(A0,LOW);
RHS.run(FORWARD);
LHS.run(FORWARD);
delay(5000);allstop();
void go(){
RHS.setSpeed(spd);
LHS.setSpeed(spd);
LHS.run(FORWARD);
RHS.run(FORWARD);
Serial.println("GoGoGo");Serial.print(spd);
void rev(int t){
LHS.run(BACKWARD);
RHS.run(BACKWARD);
delay(t);
allstop();
void allstop(){
//LHS.run(RELEASE);
//RHS.run(RELEASE);
RHS.setSpeed(0);
LHS.setSpeed(0);
void left(){
allstop();
RHS.run(FORWARD);
delay(turntime);
allstop();
void right(){
allstop();
LHS.run(FORWARD);
delay(turntime);
allstop;
int watch(){
int howfar;
int cnt=0;
while(cnt<3){
Avg[cnt]=(ultrasonic.Ranging(CM));
++cnt;
howfar=((Avg[0]+Avg[1]+Avg[2])/3);
laser(150);
delay(150);
return (howfar);
void laser(int t){
digitalWrite(A0,HIGH);delay(t);digitalWrite(A0,LOW);
void scan(){
head.write(150);
RDist=watch();
if(RDist>Slimit){allstop();}
head.write(110);
RDiag=watch();
if(RDiag>Dlimit){allstop();}
head.write(75);
Dist=watch();
if(Dist>Dlimit){allstop();}
head.write(37);
LDiag=watch();
if(LDiag>Dlimit){allstop();}
head.write(0);
LDist=watch();
if(LDist>Slimit){allstop();}
head.write(75);
Serial.print(RDist);Serial.print("-");Serial.print(RDiag);
Serial.print("-");Serial.print(Dist);Serial.print("-");
Serial.print(LDiag);Serial.print("-");Serial.print(LDist);
Serial.println("");
void loop(){
while(RUNNING==true){// if we are moving then lookout
while(cycles<=10){//while moving scan ahead
Dist=watch();Serial.println(Dist);
++cycles;}
cycles=0;
scan();//every 25 cycles do a look around
//test the motors
go();
allstop();
