@felic I would like to speak with you via DM regarding the Holofan project thread that is now closed. I have a similar project and I would like to pick you brain. Unfortunately I'm to dumb to figure out how to send you a DM and got my last post deleted when I put my email in the post.
Please Be aware that lots of people don't want DM /PM.
You could also start your own topic.
Could you also take a few moments to Learn How To Use The Forum.
- Your OS and version can be valuable information, please include it along with extra security you are using.
- Always list the version of the IDE you are using and the board version if applicable.
- Use quote or add error messages as an attachment NOT a picture.
- How to insert an image into your post. ( Thanks @sterretje )
- Add your sketch where applicable but please use CODE TAGS ( </> )
- Add a SCHEMATIC were needed even if it is hand drawn
- Add working links to any specific hardware as needed (NOT links to similar items)
- Remember that the people trying to help cannot see your problem so give as much information as you can
COMMON ISSUES
- Ensure you have FULLY inserted the USB cables.
- Check you have a COMMON GROUND where required. ( Thanks @Perry)
- Where possible use USB 2.0 ports or a USB 2.0 POWERED HUB to rule out USB 3.0 issues.
- Try other computers where possible.
- Try other USB leads where possible.
- You may not have the correct driver installed. CH340/341 or CP2102 or FT232 VCP Drivers - FTDI
- There may be a problem with the board check or remove your wiring first.
- Remove any items connected to pins 0 and 1.
COMPUTER RELATED
- Close any other serial programs before opening the IDE.
- Ensure you turn off any additional security / antivirus just to test.
- There may be a problem with the PC try RESTARTING it.
- You may be selecting the wrong COM port.
- Avoid cloud/network based installations where possible OR ensure your Network/Cloud software is RUNNING.
- Clear your browsers CACHE.
- Close the IDE before using any other serial programs.
- Preferably install IDEâs as ADMINISTRATOR or your OS equivalent
ARDUINO SPECIFIC BOARDS
- CH340/341 based clones do not report useful information to the âget board infoâ button.
- NANO (Old Types) some require you to use the OLD BOOTLOADER option.
- NANO (ALL Types) See the specific sections lower in the forum.
- NANO (NEW Types) Install your board COREâs.
- Unless using EXTERNAL PROGRAMMERS please leave the IDE selection at default âAVRISP mkIIâ.
- Boards using a MICRO usb connector need a cable that is both DATA and CHARGE. Many are CHARGE ONLY.
CREATE editor install locations.
- On macOs ~/Applications/ArduinoCreateAgent-1.1/ArduinoCreateAgent.app/Contents/MacOS/config.ini
- On Linux ~/ArduinoCreateAgent-1.1/config.ini
- On Windows C:\Users[your user]\AppData\Roaming\ArduinoCreateAgent-1.1
Performing the above actions may help resolve your problem without further help.
Language problem ?
Try a language closer to your native language:
- ä¸æ (Chinese)
- Deutsch - German
- EspaÃąol - Spanish
- Français - French
- āĻ āĻ¸āĻŽā§āĻ¯āĻŧāĻž, āĻŦāĻžāĻāĻ˛āĻž, ā¤Ŧā¤Ąā¤ŧāĨ - India
- Italiano - Italian
- Nederlands - Dutch
- Portugues - Portuguese
- Đ ĐžŅŅиŅ - Russia
- Scandinavia Swedish, Suomi - Finnish, Norsk - Norwegian
Thanks to all those who helped and added to this list.
If only because they are then restricting their useful advice to one person.
The whole reason why these fora exist as such, is so that people can research for previous solutions to the same problem. That hopefully allows them to solve the problem with no further effort from the advisers. Only where that fails should it be necessary for someone to ask a new question
On this account, the concept with the newer forum of "closing" threads, is a trifle inappropriate. If a new question adds information to an older thread, then the older thread is essential background. Presumably the intent of "closing" is indeed, to discourage inappropriate diversions.
You have a short memory The old forum also had that functionality.
But it did not happen automatically.
I think it actually did happen automatically. You can't expect moderators to go through topics
@h1ghy1eld If you want to DM me, just do so. I don't know if I can help though.
The whole concept of closing threads automatically or claiming that replying to old threads is a bad thing is baseless and ridiculous in my opinion...
Topic split from another topic. Please do not add your own questions to the end of other people's topics.
Could you take a few moments to Learn How To Use The Forum
Thank you.
Yep.
