DM860H motor driver with Nema34(Stepper motor) coding problem
I’m making a ventilator that responds to internal and external conditions and operates on its own.
However, the reaction from all other conditions is correct, but only the stepper motor, which is the axis of rotation of the ventilator, does not operate under conditions.
For example, the ventilator itself needs to rotate +180 degrees or -180 degrees depending on internal and external conditions, but I don’t know the code that controls its behavior.
Please check the code below to see what the problem is.
Please also refer to the notes.
#include <DHT.h>
#define DHTTYPE DHT22
#define DHTPIN1 52
#define DHTPIN2 53
DHT dht1(DHTPIN1,DHTTYPE);
DHT dht2(DHTPIN2,DHTTYPE);
#include <Wire.h>
LiquidCrystal_I2C lcd(0x27,20,4);
#include <SoftwareSerial.h>
SoftwareSerial mySerial(13,11);
#include <AccelStepper.h>
int direcPin = 7;
int pulsePin = 6;
AccelStepper stepper(1, pulsePin, direcPin);
int MQ5LPG=48,MQ7CO=49;
int fan=4,dir=3,buzzer=44;
float Tin=0,Tout=0;
int target=0,angle=0;
unsigned char Send_data[5] = {0x11,0x02,0x0b,0x01, 0xE1};
unsigned char Receive_Buff[20];
unsigned long PM25;
unsigned long COM_SUCCESS, COM_COUNT;
unsigned char recv_cnt = 0;
void Send_CMD(void)
 unsigned char i;
 for(i=0; i<5; i++)
   mySerial.write(Send_data[i]);
   delay(1);
unsigned char Checksum_cal(void)
 unsigned char count, SUM=0;
 for(count=0; count<19; count++)
    SUM += Receive_Buff[count];
 return 256-SUM;
void setup(){
pinMode(fan,OUTPUT); pinMode(dir,OUTPUT); pinMode(buzzer,OUTPUT); pinMode(11,OUTPUT);
pinMode(13,INPUT);
lcd.init(); lcd.backlight();
Serial.begin(9600); while(!Serial);
mySerial.begin(9600); while(!mySerial);
digitalWrite(dir, LOW);
void loop(){
 COM_COUNT++;
 Send_CMD();
 while(1)
   if(mySerial.available())
      Receive_Buff[recv_cnt++] = mySerial.read();
     if(recv_cnt ==20){recv_cnt = 0; break;}
 if(Checksum_cal() == Receive_Buff[19])
       COM_SUCCESS++;
       PM25 = (unsigned long)Receive_Buff[3]<<24 | (unsigned long)Receive_Buff[4]<<16 | (unsigned long)Receive_Buff[5]<<8| (unsigned long)Receive_Buff[6];
       Serial.write("    PM2.5 : ");
       Serial.println(PM25);
    Serial.write("CHECKSUM Error");
Tin=dht1.readTemperature(); Serial.write("DHT_1: "); Serial.println(Tin);
Tout=dht2.readTemperature(); Serial.write("DHT_2: "); Serial.println(Tout);
Serial.write("MQ5LPG: "); Serial.println(digitalRead(MQ5LPG));
Serial.write("MQ7CO: "); Serial.println(digitalRead(MQ7CO));
int dif=Tin-Tout; // Calculate the difference between indoor and outdoor temperature.
 if( !digitalRead(MQ5LPG) || !digitalRead(MQ7CO) || (PM25>=35.1) ){    // If LPG gas or CO is detected or fine dust concentration is high
    if( angle==0){  angle=180; stepper.moveTo (200);  stepper.run ();   }  // Operate the step motor to activate the ventilator in the external direction
   analogWrite(fan,150); tone(buzzer,500,100); // Turn high speed and release the inner air outside.
else if( dif>0 ){ // If the room temperature is higher
if( Tin>=25 ){  // If the room temperature is over 25 degrees
analogWrite(fan,150); noTone(buzzer); // Turn high speed and release the inner air outside.
 else if( dif<0 ){ // If the outdoor temperature is higher
 if( Tin<=18 ){  // If the room temperature is below 18 degrees
    if( angle==180){  angle=0; stepper.moveTo (-200);  stepper.run ();   } // Operate the step motor to activate the ventilator in the inner direction.
  analogWrite(fan,150); noTone(buzzer); // Turn high speed and release the outside air inside.
 else{                                                         // If these conditions are not met,
  analogWrite(fan,0); noTone(buzzer); // Stop
 lcd.setCursor(0,0); lcd.print("Tin: "); lcd.print(Tin); lcd.print("Tout: "); lcd.print(Tout);
 lcd.setCursor(0,1); lcd.print("D: ");  lcd.print(PM25);
 delay(3000);
What type of stepper ?
How is the stepper powered ?
How is the stepper wired ?
Do the examples with the AccelStepper library work ?
And i tried Demo code of AccelStepper, and that worked well
So i think wiring is right and power is enough
Definitely There’s a problem with the code.
Especially
" if( !digitalRead(MQ5LPG) || !digitalRead(MQ7CO) || (PM25>=35.1) ){ // If LPG gas or CO is detected or fine dust concentration is high
if( angle==0){ angle=180; stepper.moveTo (200); stepper.run (); } // Operate the step motor to activate the ventilator in the external direction "
Check this part please…
#include <DHT.h>
#define DHTPIN1 52
#define DHTPIN2 53
#include <Wire.h>
int direcPin = 7;
int pulsePin = 6;
float Tin=0,Tout=0;
unsigned long PM25;
void Send_CMD(void)
 unsigned char i;
 for(i=0; i<5; i++)
   delay(1);
 return 256-SUM;
void setup(){
pinMode(13,INPUT);
void loop(){
 COM_COUNT++;
 Send_CMD();
 while(1)
       COM_SUCCESS++;
 delay(3000);
Simple Question
What is the problem with the code below?
You tell us.
A closing bracket is missing :slight_smile:
Indent your code correctly
if( !digitalRead(MQ5LPG) || !digitalRead(MQ7CO) || (PM25>=35.1) ) // If LPG gas or CO is detected or fine dust concentration is high
    if( angle == 0 ) // Operate the step motor to activate the ventilator in the external direction
        angle = 180;
        stepper.moveTo(200);
        stepper.run();
@gongdoll, do not cross-post. Threads merged.
It's quite odd that you mash multiple statements onto a single line as if vertical space was precious, yet you add a bunch of random pointless blank lines. Both these things make the code more difficult to read, which makes errors more likely and finding anything in the code slower.
