DMD library and Bridge.
I am trying to make a DMD sign with a Yun. I have the DMD library working perfectly. I extended the bridge examples to make my own api which works great (tested from the console). When I try to combine the two, as soon as dmd.begin(); is called I lose all communications with the Yun.
I think maybe the problem is with the Yun serial limitations, but I'm not sure. Does anyone here have any ideas?
This is the code that I am trying.
#include <Bridge.h>
#include <YunServer.h>
#include <YunClient.h>
#include <Console.h>
#include <SPI.h>
#include <DMD2.h>
#include <fonts/SystemFont5x7.h>
SoftDMD dmd(3,1);
YunServer server;
  pinMode(13, OUTPUT);
  digitalWrite(13, LOW);
  Bridge.begin();
  digitalWrite(13, HIGH);
  server.listenOnLocalhost();
  server.begin();
  while (!Console);
  Console.println("Let's go ...");
  dmd.setBrightness(255);
  dmd.selectFont(SystemFont5x7);
  // Whenever this is called bridge no longer seems to work
  dmd.begin();
  YunClient client = server.accept();
  if (client) {
    process(client);
    Console.println(" We have client");
    client.stop();
  delay(50);
void process(YunClient client) {
  String command = client.readStringUntil('/');
  if (command == "digital") {
    digitalCommand(client);
  if (command == "dmd") {
    dmdCommand(client);
void digitalCommand(YunClient client) {
  int pin, value;
  // Read pin number
  pin = client.parseInt();
  // If the next character is a '/' it means we have an URL
  // with a value like: "/digital/13/1"
  if (client.read() == '/') {
    value = client.parseInt();
    digitalWrite(pin, value);
  else {
    value = digitalRead(pin);
  // Send feedback to client
  client.print(F("Pin D"));
  client.print(pin);
  client.print(F(" set to "));
  client.println(value);
  // Update datastore key with the current pin value
  String key = "D";
  key += pin;
  Bridge.put(key, String(value));
void dmdCommand(YunClient client) {
  String dmdmessage = client.readStringUntil('\n');
  client.print(F("DMD"));
  client.println(dmdmessage);
  String key = "DMD";
  key += dmdmessage;
  Bridge.put(key, String(dmdmessage));
