I am on a scoreboard project using 2 P10 LED panels with IR Remote Control.
I am using DMD2 library for P10 display and IRremote for the remote control;
I have decoded the remote control through (irrecv.decodedIRData.command) and received the following key codes for each button in decimals:
CH- 69
CH 70
CH+ 71
REWIND 68
FORWARD 64
PLAYPAUSE 67
( - ) 7
( + ) 21
EQ 9
0 22
100+ 25
200+ 13
1 12
2 24
3 94
4 8
5 28
6 90
7 66
8 82
9 74
However, when both of the DMD2 library and IRremote are combined, theres interference within the IR receiver. It does not print out value as it does when not combined with the DMD2 library.
Here are the codes combined:
#include <DMD2.h>
#include <EEPROM.h>
#include <fonts/MyBigFont.h>
#include <IRremote.h>
#define WIDTH 2
#define HEIGHT 1
int RECV_PIN = 2;
IRrecv irrecv(RECV_PIN);
// CAR MP3 (decodedIRData.command)
// #define IR_BUTTON_CH- 69
// #define IR_BUTTON_CH 70
// #define IR_BUTTON_CH+ 71
// #define IR_BUTTON_REWIND 68
// #define IR_BUTTON_FORWARD 64
// #define IR_BUTTON_PLAYPAUSE 67
// #define IR_BUTTON_- 7
// #define IR_BUTTON_+ 21
// #define IR_BUTTON_EQ 9
// #define IR_BUTTON_0 22
// #define IR_BUTTON_100+ 25
// #define IR_BUTTON_200+ 13
#define IR_BUTTON_1 12
// #define IR_BUTTON_2 24
// #define IR_BUTTON_3 94
// #define IR_BUTTON_4 8
// #define IR_BUTTON_5 28
// #define IR_BUTTON_6 90
// #define IR_BUTTON_7 66
// #define IR_BUTTON_8 82
// #define IR_BUTTON_9 74
SoftDMD dmd(WIDTH, HEIGHT);
byte Brightness;
byte debounce = 500;
int leftScore = 0;
int rightScore = 0;
char dmdBuff[10]; // define dmdBuff as a character array with length 10
Brightness = EEPROM.read(0);
dmd.begin();
dmd.setBrightness(10);
dmd.selectFont(MyBigFont);
dmd.clearScreen();
irrecv.enableIRIn();
irrecv.blink13(true);
void DisplayScore() {
static unsigned long lastDisplayTime = 0;
if (millis() - lastDisplayTime > 500) {
sprintf(dmdBuff,"%d",leftScore) ;
dmd.drawString( 7, 0, dmdBuff );
dmd.drawString( 29, 0, "-" );
sprintf(dmdBuff,"%2d",rightScore);
dmd.drawString( 37, 0, dmdBuff );
lastDisplayTime = millis();
DisplayScore();
if (irrecv.decode()) {
Serial.println(irrecv.decodedIRData.command);
irrecv.resume(); // Receive the next value
switch (irrecv.decodedIRData.command) {
case IR_BUTTON_1: // Button 1
leftScore++;
DisplayScore();
// case IR_BUTTON_2: // Button 2
// rightScore++;
// DisplayScore();
// break;
// case IR_BUTTON_3: // Button 3
// leftScore--;
// DisplayScore();
// break;
// case IR_BUTTON_4: // Button 4
// rightScore--;
// DisplayScore();
// break;
// case IR_BUTTON_5: // Button 5
// leftScore = 0;
// rightScore = 0;
// DisplayScore();
// break;
