DMV style queue
I can’t figure out what is wrong with my code and it’s also creating errors in my arduino.
Serial monitor loops numbers 1, 2, 3, 4 then i get the message “QUEUE: insufficient memory to create a new node.”
here is my code.
//Libraries used:
//QueueList
//Sindormir Seven segment
#include <SindormirSevenSegments.h>
#include <QueueList.h>
int desk1 = 8;
int desk2 = 9;
int desk3 = 11;
int desk4 = 12;
int Teacher = 10;
const int desk1no = 1;
const int desk2no = 2;
const int desk3no = 3;
const int desk4no = 4;
SindormirSevenSegments my7S(0,1,2,3,4,5,6,7);
QueueList <int> queue; //TRY WITH STRING IF DOESNT WORK
 pinMode(desk1,INPUT);
pinMode(desk2,INPUT);
pinMode(desk3,INPUT);
pinMode(desk4,INPUT);
pinMode(Teacher,INPUT);
queue.setPrinter (Serial);
if (desk1=HIGH)
queue.push (desk1no);
if (desk2=HIGH)
queue.push (desk2no);
if (desk3=HIGH)
queue.push (desk3no);
if (desk4=HIGH)
queue.push (desk4no);
if (Teacher=HIGH)
//queue.pop(); // may require Serial.println
Serial.println (queue.pop ());
 if (Serial.available() > 0) {
   int inByte = Serial.read();
switch (inByte) {
case '1':
    my7S.print(1);
     case '2':
     my7S.print(2);
     case '3':
     my7S.print(3);
     case '4':
     my7S.print(4);
     default:
     my7S.print(0);
// else {
//  my7S.print(0);
if (desk1=HIGH)
Oops.
Please use code tags when posting code.
I noticed that error and updated my code. It’s still not working right
//Libraries used:
//QueueList
const int desk1pin = 8;
const int desk2pin = 9;
const int desk3pin = 11;
const int desk4pin = 12;
const int teacherpin = 10;
int Desk1;
int Desk2;
int Desk3;
int Desk4;
int Teacher;
  pinMode(desk1pin,INPUT);
pinMode(desk2pin,INPUT);
pinMode(desk3pin,INPUT);
pinMode(desk4pin,INPUT);
pinMode(teacherpin,INPUT);
pinMode(0,OUTPUT);
pinMode(1,OUTPUT);
pinMode(2,OUTPUT);
pinMode(3,OUTPUT);
pinMode(4,OUTPUT);
pinMode(5,OUTPUT);
pinMode(6,OUTPUT);
pinMode(7,OUTPUT);
  Desk1 =digitalRead(desk1pin);
  Desk2=digitalRead(desk2pin);
  Desk3=digitalRead(desk3pin);
  Desk4=digitalRead(desk4pin);
  Teacher=digitalRead(teacherpin);
//  delay(1000);
if (Desk1==HIGH)
if (Desk2==HIGH)
if (Desk3==HIGH)
if (Desk4==HIGH)
if (Teacher==HIGH)
switch (inByte) {
case '1':
     my7S.print(1);
      case '2':
      my7S.print(2);
      case '3':
      my7S.print(3);
      case '4':
      my7S.print(4);
      default:
      my7S.print(0);
// else {
 //  my7S.print(0);
How many times do you think Desk1 (for example) is HIGH?
How about only pushing something when it becomes HIGH?
That is what i want to do.
The plan is that it's going to display the number of the desk that has pressed the pushbutton. When the 'Teacher" pushbutton is pressed it flips the 7 segment to the number that is next in the queue. I'm just not sure where to go from here.
Also, i'm finding that i have to take the circuit apart and switch boards in order to upload new code. I get timeout errors.
Shouldn't you be checking whether the inputs have become pressed rather than if they are pressed ? Otherwise each time through loop() another entry will be placed in the queue.
SindormirSevenSegments my7S(0,1,2,3,4,5,6,7);Are you using the serial pins (0 and 1) for the display ? If so then this may be interfering with the code upload.
I just switched the 0 and 1 pins and it solved the uploading problem.
How do i make it so it reads when it becomes pressed? I'm new to this.
If it wasn't pressed last time you looked at it, and it is pressed now, it has become pressed.
AWOL:
The state change detection example illustrates this.
