Dmx dimmer: problem with dmx library and dimmer library
Hi! I want to ask a suggestion. I'm trying to develop an AC dimmer controlled by DMX, but I have a problem using the DmxSerial library (to read the dmx data) and the RBDDimmer library that control the dimmer. The dimmer doesnt work when I include also the dmx serial library. I think it could be a problem of incompatibility between the two libraries (maybe they use something together such as interrupt ?)
Someone know a solution ?
Thanks
It might help if you could post your code; in case you have forgotten, please use code tags using the </> button intghe reply window.
Please provide links to the DmxSerial library and the RBDDdimmer library.
That would more than likely result in a linker error (something in the line of multiple __vector, not sure of the exact mesage).
Thank you for answering... Here's the library:
https://www.arduino.cc/reference/en/libraries/dmxserial/
https://github.com/RobotDynOfficial/RBDDimmer
The code is really simple for now:
#include <DMXSerial.h>
#include <RBDdimmer.h>
const int dimmer_1 = 11;
dimmerLamp blinder_1(dimmer_1);
const int led = 13;
  pinMode(led,OUTPUT);
  DMXSerial.init(DMXReceiver);
  blinder_1.begin(NORMAL_MODE, ON);
  blinder_1.setPower(0);
  blinder_1.setPower(255);
The dimmer works if i comment the line
PS. the code for now doesn't use dmx signal.
No compile error.
thanks
I have never used the dmxserial library, but use a different system for receiving dmx.
Receiving data at 250kbps continuously (seriously, DMX is a constant flow of data with a short 80us break) put';s quite a lot of strain on the CPU.
Usually you will be better of using a single frame receiving method on an AVR.
I have no idea how the AC dimmer works, either, but you haven't shown the wiring as yet.
I guess a zero-cross detection method is used from what i can tell from the SRC, and the combination of that with DMX reception, will just not work on an AVR. A faster processor will be required.
Ok so it is probably a problem related to the performance of the arduino nano. Too slow to get the dimmer works correctly.
Thanks
